How to display a DWG preview using MFC function ??
Can't found on article 5298 the downloadfile 5298.zip
any idear for a example ??
Best regards
Georg
I'll give you a sample on how to show the preview image in a dialog
-Create a dialog using ClassWizard.
-Create a Picture object in your dialog. In the properties, set the type to
rectangle and the color to black.
-Change the ID of the picture from IDC_STATIC to IDC_PREVIEW (for example)
-Using ClassWizard, create a member variable of the type CStatic to this
control. Name it as m_preview
-Create a button in your dialog and put the cond below on it:
CFileDialog fileDlg( TRUE, ".dwg", NULL, OFN_OVERWRITEPROMPT, "AutoCAD
Drawings (*.dwg)|*.dwg||", this);
if ( fileDlg.DoModal() == IDOK )
CString szDwg;
szDwg = fileDlg.GetPathName();
Adesk::UInt32 color = 0;
acdbDisplayPreviewFromDwg(szDwg, m_preview.m_hWnd, &color);
-Include stdarx.h in your dialog.
I tested it before post here and it worked.
Vinicius
Georg Erlenhoff escreveu nas notícias de
mensagem:[email protected]...
Best regards
Georg
This will work, but it will be erased the first time
your window is repainted.
To do this, you either need to call acdbDisplayPreviewFromDwg()
from your OnPaint() handler (ouch!), or better, cache the image
in a memory DC and bitblt to the window DC from OnPaint().
So it may be better to get the bitmap directly by calling
acdbGetPreviewBitmapFromDwg() and then display it in your
OnPaint() handler.
"Vinicius Pontes" wrote in message
news:[email protected]...
to
> CString szDwg;
> Vinicius
> Best regards
> Georg
How I can get the Bitmap to create a BitmapButton ??
Some source there ??
Georg
"Tony Tanzillo" schrieb im Newsbeitrag
> OnPaint() handler.
> to
example)
> > CString szDwg;
> > Vinicius
de
> > Best regards
> > Georg
