How to define the max size and min size of a floating dockcontrolbar?
Hi,everyone:
    I've got some troubles in defining the max and min size of a floating dockcontrolbar.I overwrite the OnGetMinMaxInfo() function with following code:
void CMyDockControlBarChildDlg::OnGetMinMaxInfo(MINMAXINFO* lpMMI)
    lpMMI->ptMinTrackSize.x = 500;
    lpMMI->ptMinTrackSize.y = 500;
    lpMMI ->ptMaxTrackSize.x = 800;
    lpMMI ->ptMaxTrackSize.y = 800;
    CAcUiDialog::OnGetMinMaxInfo(lpMMI);
It didn't work. So I tried in an empty MFC application with CFrameWnd::OnGetMinMaxInfo(), it worked successfully. Meanwhile I noticed that ARXWizardMFCSupport offers a CAdUiDockFrame class, but I can't create a class based on it. So can anybody tell me why the function doesn't work and teach me how to achieve my goal?
Thanks a lot.
thierry_prince
In my application, I use some custom palettes.
For this purpose, I derive the CAdUiPaletteSet class for the docking palette set (CAdUiPaletteSet derives itself from CAdUiDockControlBar), and I derive from CAdUiPalette for the palettes.
To control the palette size, I use the GeMinimumSize() and GetMaximumSize() virtual methods.
In the case of a CAcUiDockControlBar or CAdUiDockControlBar, I would try the virtual methods GetFloatingMinSize() or OnUserSizing().
I hope this helps you.
Cheers,
Thierry
It didn't work 😞
thank you all the same
