How to catch AutoCAD aborting
Hi everybody!
I have a large project consist of several DBXs and ARXs. Sometimes I
obtains "AutoCAD Error Aborting" message box: "FATAL ERROR:
Unimplemented AcRxClass::copyFrom() function invoked".
After pressing "Ok" button I obtains "Access violation" exception and
call stack shows something in depth of MFC. I'm already switch "Stop
always" for "Access violation" exceptions.
Does anybody know how to catch real call stack? Any ideas?
Best regards,
Sergey Y. Kazakov
I'm currently in the process of tracking done a similar problem. So far
I have found a problem with the usage of acedSetCurrentView(). This
function is used in our ARX application to set the view in a model space
viewport contained in the paperspace. It switches ACAD into model space
if neccessary (which it is in our case).
In my application the problem seems to vanish, if I reswitch to paper
space after the call. The real problem might be caused by some other
code later on, but maybe this can help you at least to get on the right
track during your search.
To get a useful call stack, one would need a debug version of AutoCAD I
suppose.
Steffen Imhof Im Matthäuskreuz 3
ixact GmbH 64367 Mühltal
Das Software-Bauhaus +49 6151 503600
> I'm currently in the process of tracking done a similar problem. So far I
> space after the call. The real problem might be caused by some other code
> later on, but maybe this can help you at least to get on the right track
> during your search.
Thank you, Steffen, for your help! Seem my problem is in switching between
Model and
Paper spaces too. I'll inform if I catch the problem.
> suppose.
I'm already use debug version. Bu call stack is invalid. I can't catsh the
problem
even using NuMega BoundsChecker.
Best regards
Sergey Y. Kazakov
