Explode with the ACAD EXPLODE Command
Hi all!
My problem:
I have a DWG File with some AcDbBlockReferences. Every
Blockreference contains of a Polyface Mesh. This Polyface
Mesh has some X-Data with information I want to read.
If I explode the Block with the ACAD EXPLODE Command,
the resulting Polyface Mesh contains the X-Data and
I can read them out.
Now I want to do this automatically with my ARX-App.
If I explode the Block using eplode()-function, I get
a pointer to the Polyface Mesh, but this Entity has
no X-Data saved.
Here is a codesnip:
if(pBlkRef->explode(EntArray) == Acad::eOk){
        if(EntArray.length() <= 0){
                pModelSpace->close();
                pBlkRef->close();
                return(false);
        for(int i = 0; i < EntArray.length(); i++){
                es = pModelSpace->appendAcDbEntity(ObjId,
(AcDbEntity*)EntArray);
                ((AcDbEntity*)EntArray)->close();
                if(es == Acad::eOk)
                        ObjArray.append(ObjId);
        pBlkRef->close();
        return(true);
Thanks for any help, Markus
AcDbBlockReference::explode() uses
getTransformedCopy() on each entity in the block definition to create the
explode set.  Unfortunately, AcDbPolyFaceMesh::getTransformedCopy() doesn't
copy the xdata to the copy.
All I can think of is that you could have your code
find the source polyfacemesh and copy the xdata from it to the polyfacemesh copy
after the explode is complete.
Hi
all!
My problem:
Every
Mesh has
the resulting
Now I want
has
no X-Data saved.
Here is a codesnip:
Acad::eOk){
0){
                pBlkRef->close();
                return(false);
        for(int
i++){
                es
                if(es
Acad::eOk)
        pBlkRef->close();
        return(true);
Hi!
Hi!
Thanks for your help!
> Unfortunately, AcDbPolyFaceMesh::getTransformedCopy() doesn't copy the
> xdata to the copy. All I can think of is that you could have your code
> polyfacemesh copy after the explode is complete.
How can I do this? Can you give me a hint or some
documentation?
Markus
You'll have to get the objectId of the AcDbBlockTableRecord that the
blockReference references, then get an interator for that BlockTableRecord
and iterate through its contents looking for the polyfacemesh. Once you've
got the source polyfacemesh object you can use it's xData() method to get
its xdata. You can then use the setXData() method on the copy passing in
the data list you got from the source object's xData() method.
"Markus Griesser" wrote in message
news:AEAC4C6A2C2B4766BF34368C765FA5F8@in.WebX.maYIadrTaRb...
> Hi!
> Hi!
> documentation?
> Markus
Hi!
Thanks for your help! It works now...
Markus
