how to cancel a special operation with reactor or something else?
I want to do such work below,
there is a AcdbLine and a AcdbCircle in a dwg, if I move the circle exactly to the end of the line, then dothing, but if I move the circle to other place (not on the two ends of the line),then the circle automatically goes back to its old postion.   but how to implement this with objectARX?  I guess some reactor object shoud be used.
Alexander.Rivilis
If I understand you correctly, then we are talking about Associative Framework.
You can read ObjectARX for AutoCAD 2013: Developer Guide > Advanced Topics > Advanced Topics > Associative Framework.
Also useful topics:
Associative Framework: How to delete constraints applied to a specific entity?
A simplified .NET API for accessing AutoCAD parameters and constraints
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
it is hard for me to tell something in English correctly.
I want to cancel some operation.   For example , I draw a line in Autocad, then I move one end of the line to a new place, is there any way to cancel this operation(move one end to a new place) using objectARX (2008 if possible)
Alexander.Rivilis
To understand that it is not easy you can read (completely):
Locking an Entity in AutoCAD using ObjectARX
Expert Elite Member
