How to avoid AutoCAD to crash?
D_D_K
D_D_K
I used this code on autocad2021 but autocad was crashing at the end of the code.
Looks like the problem is with Accarray.
how can i fix this? despite having met many times, but I still haven't really figured out!
Alexander.Rivilis
Try this code instead:
//----- acrxEntryPoint.cpp
#include "StdAfx.h"
#include "resource.h"
#define szRDS _RXST("")
//----- ObjectARX EntryPoint
class COffsetPolylineApp : public AcRxArxApp {
public:
  COffsetPolylineApp() : AcRxArxApp() {}
  virtual AcRx::AppRetCode On_kInitAppMsg(void* pkt) {
    AcRx::AppRetCode retCode = AcRxArxApp::On_kInitAppMsg(pkt);
    return (retCode);
  virtual AcRx::AppRetCode On_kUnloadAppMsg(void* pkt) {
    AcRx::AppRetCode retCode = AcRxArxApp::On_kUnloadAppMsg(pkt);
    return (retCode);
  virtual void RegisterServerComponents() {  }
  static void RivilisOffsetPoly()
    ads_point p; ads_name en;
    static double distOffset = 1.0;
    if (acedEntSel(L"\nSelect Polyline: ", en, p) != RTNORM)
      return;
    AcDbObjectId idPoly;
    acdbGetObjectId(idPoly, en);
    if (!idPoly.objectClass()->isDerivedFrom(AcDbPolyline::desc()))
      acutPrintf(L"\nIt is not a AcDbPolyline!");
      return;
    AcGeMatrix3d mat; acedGetCurrentUCS(mat);
    AcDbObjectPointer<AcDbPolyline> pPoly(idPoly, AcDb::kForRead);
    AcGePoint3d pOnPline;
    pPoly->getClosestPointTo(asPnt3d(p).transformBy(mat), pOnPline);
    pOnPline.transformBy(mat.inverse());
    if (acedGetDist(asDblArray(pOnPline), L"\nOffset distance: ", &distOffset) == RTCAN)
        return;
    AcDbBlockTableRecordPointer pBtr(pPoly->ownerId(), AcDb::kForWrite);
    AcDbVoidPtrArray pArr;
    if (pPoly->getOffsetCurves(distOffset, pArr) == Acad::eOk)
      for (int i = 0; i < pArr.length(); i++)
        pBtr->appendAcDbEntity(reinterpret_cast<AcDbEntity *>(pArr[i]));
        reinterpret_cast<AcDbEntity*>(pArr[i])->close();
    pArr.setLogicalLength(0);
    if (pPoly->getOffsetCurves(-distOffset, pArr) == Acad::eOk)
        pBtr->appendAcDbEntity(reinterpret_cast<AcDbEntity*>(pArr[i]));
IMPLEMENT_ARX_ENTRYPOINT(COffsetPolylineApp)
ACED_ARXCOMMAND_ENTRY_AUTO(COffsetPolylineApp, Rivilis, OffsetPoly, OffsetPoly, ACRX_CMD_MODAL, NULL)
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
D_D_K
Thanks expert for the both answers, my problem is solved!
How can we just shift outward
Alexander.Rivilis
Is it a question? You can calculate area of both polylines. Biggest area - outward shifted polyline.
Expert Elite Member
