Access Violation inside of REGEN3
fehrsZBFB9
fehrsZBFB9
Hallo Guys,
I sometimes get an Access Violation inside of REGEN3. I call it after AcDbVisibilityOverrule has done its work and the display needs an refresh. It doesn't matter if I do it per acedCommandS from inside a command or by hand. It only happens from time to time. What could be the reason for such an access violation? I'm not sure where to start. Any hints? It does not help to replace REGEN3 with native C++ functions. If I do it crashes inside of acedRedraw. There was a previous call to REGEN which always runs fine.
tbrammer
Check whether you close all objects that you opened within your overridden methods.
Avoid to open any objects kForWrite within your implementation of
   AcDb::Visibility AcDbVisibilityOverrule::visibility(const AcDbEntity* pSubject)
Also I would check whether your AcDbVisibilityOverrule causes the problem by simply returning the defaults:
AcDb::Visibility MyVisibilityOverride::setVisibility(
    AcDbEntity *pSubject,
    AcDb::Visibility newVal,
    Adesk::Boolean doSubents
   return AcDbEntity::subSetVisibility(pSubject, newVal, doSubents);
   // your Code
AcDb::Visibility MyVisibilityOverride::visibility() {
    return AcDbEntity::subVisibility();
    /// your code
If you still get crashes you have to search the reason elsewhere.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
fehrsZBFB9
Maybe this crash has nothing to do with my code. It only happens with Advance Steel. Neither with pure AutoCAD nor with Architecture. Thanks anyway.
