How to accept Spacebar as a char when in the acquireString function?
A JIG project,I meet a problem:
How to accept  Spacebar  as a char,not as a return ,  when  I using  the acquireString function?
Like this:
setUserInputControls ((AcEdJig::UserInputControls)(m_flag));
TCHAR * pStr=new TCHAR[1024];
status = acquireString(pStr);
m_strInput.Format(_T("%s"),pStr);
delete[] pStr;
pStr =NULL;
I posted my project  file to here, wish someone can help me!
Thank you  very much.
fenton_webb
Did you see the help documentation for AcEdJig::setUserInputControls()
AcEdJig::kGovernedByOrthoMode
Sets the "honor ORTHOMODE sysvar" bit of the user input request packet. By default, this bit is not set. Note that the AcEdJig::acquirePoint(AcGePoint3d&, const AcGePoint3d&basePnt) method always honors the ORTHOMODE sysvar, regardless of this bit's state.
AcEdJig::kNullResponseAccepted
Sets the "null input acceptable" bit of the user input request packet. This bit is clear by default, and null input is not acceptable.
AcEdJig::kDontEchoCancelForCtrlC
Sets the "Don't echo *Cancel* for Ctrl-C's" mode. This is off by default, and *Cancel* is displayed.
AcEdJig::kDontUpdateLastPoint
Sets the "Don't update last point" mode. The last point is updated by default.
AcEdJig::kNoDwgLimitsChecking
Sets the "Do not check point limits" mode. Drawing limits are checked by default.
AcEdJig::kNoZeroResponseAccepted
Sets the "Don't accept zero values" mode. Zero values are accepted by default. This works for the functions acquireDist() and acquireAngle() only.
AcEdJig::kNoNegativeResponseAccepted
Sets the "Don't accept negative values" mode. Negative values are accepted by default. This works for the functions acquireDist() and acquireAngle() only.
AcEdJig::kAccept3dCoordinates
Sets the "Accept Z coordinate" mode. Input is restricted to 2d input by default.
AcEdJig::kAcceptMouseUpAsPoint
Sets the "Use mouse up for points" mode. Mouse-up events do not register as points by default.
AcEdJig::kAnyBlankTerminatesInput
Sets the "Any blank terminates input" mode. This mode is off by default.
AcEdJig::kInitialBlankTerminatesInput
Sets the "Initial blank terminates input" mode. This mode is off by default.
AcEdJig::kAcceptOtherInputString
Sets the "Accept non-keyword string input" mode. This mode is off by default.
AcEdJig::kUseBasePointElevation
The elevation of the base point is applied to the point which is being acquired in jigging
Fenton Webb
AutoCAD Engineering
Yes ,I saw it. even I trid the  AcEdJig::kAcceptOtherInputString  flag,but I can't get the right result .
