How do I read Custom Properties/Attributes from an anonymous object?
jlobo2
Message 1 of 9
jlobo2
I can read the attributes of the object, but not sure how to read the below:
Any help will be greatly appreciated.
Replies (8)
Message 2 of 9
Alexander.Rivilis
C# or C++? If C# - you (as usually)  created topic in wrong forum. Right forum is: https://forums.autodesk.com/t5/net/bd-p/152
Also no difference between getting custom properties from anonymous and named block references.
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 9
jlobo2
Yes @Alexander.Rivilis , I did post it on the .NET forum as well.
https://forums.autodesk.com/t5/net/how-do-i-read-custom-properties-attributes-from-an-anonymous/td-p...
My bad, I thought this forum was for C++.
How to access the custom properties for the block references or anonymous blocks in C++ though?
Thank You for your help once again.
Message 4 of 9
Alexander.Rivilis
https://adndevblog.typepad.com/autocad/2012/08/how-to-access-and-modify-a-dynamicblockreference-prop...
Expert Elite Member
Message 5 of 9
jlobo2
@Alexander.Rivilis , How do I set the property value for the block?
I am using the following code, but it does not update the value.
if (wcscmp(blkProp.propertyName().kACharPtr(), L"Visibility1") == 0)
	AfxMessageBox(_T("Visibility1 Found"));
	blkProp.setValue(_T("TEST"));
Also, how do I access or print this following value in TCHAR?
//Get allowed values for property
AcDbEvalVariantArray evalAry;
if ((err = blkProp.getAllowedValues(evalAry)) == Acad::eOk)
if (evalAry.length() >= 1) { AcDbEvalVariant eval = evalAry[1];
// How do I access this value as a TCHAR or string
// to print in the command line?
if (!blkProp.readOnly()) { if ((err = blkProp.setValue(eval)) != Acad::eOk) { acutPrintf(L"\nError setting property value..."); } } } }
Message 6 of 9
Alexander.Rivilis
Not
but
AcDbEvalVariant eval = evalAry[0];
Expert Elite Member
Message 7 of 9
jlobo2
Ok. I am getting a hang of it now. Basically we are accessing from a set of pre-defined objects and modifying the custom properties to dynamically change it.
@Alexander.Rivilis  am I on the right track?
Also, how do I access the text value of the property?
// How to display the value as text? AfxMessageBox( blkProp.value() ); blkProp.setValue(_T("B1")); }
Message 8 of 9
jlobo2
@Alexander.Rivilis  Nevermind - I got it working through the code in C#.NET
Thanks a lot once again for your help. I really appreciate it.
Message 9 of 9
Alexander.Rivilis
As far as AcDbEvalVariant is derived from struct resbuf, you can use function dxfToStr  or printResbufChain (which defined in ObjectARX SDK samples\database\ARXDBG\AcadUtils\ArxDbgRbList.cpp) to convert AcDbEvalVariant to CString
Expert Elite Member
