How Can I Move Objects
Message 1 of 11
Hi.
I Have AcDbEntity and i want to move it to specific point, How ???
Thanks A Lot For Helping.
Replies (10)
Message 2 of 11
On Mon, 24 Nov 2003 02:15:36 -0800, Iggo wrote:
> Hi.
AFAIK, you can't 😞
You need to open the entity as the type it is, i.e. AcDbLine, AcDbCircle,
AcDbPolyline, etc... and then each class has it's different way of changing
the insertion point
This is one of the most stupid things that Autodesk has done!
I can't figure out why it is done this way, every entity needs an insertion
point... But now maybe I will know 😉
// Anders
Message 3 of 11
transform(...)
"Iggo"
??????:[email protected]...
> Hi.
Message 4 of 11
> AFAIK, you can't 😞
> AcDbLine, AcDbCircle, AcDbPolyline, etc... and then
> each class has it's different way of changing the insertion point
I'm afraid you're mistaken.
You can move any entity using AcDbEntity::transformBy()
AcadXTabs: Document Tabs for AutoCAD
http://www.acadxtabs.com
Message 5 of 11
Well, that's no suprise 😉
Would you Please post an sample!
I don't understand how you can move the entity without knowing it's
insertion point and to know this I must have the actual type, e.g.
AcDbCircle, don't I??
// Anders
Message 6 of 11
You don't need to know how to move any entity, because
each entity knows how to "move" itself, when it is told
to do that, and the only thing you need to tell an entity
is how far and in what direction to move, right?
That's the whole point to "object oriented". Each object
encapsulates the intelligence and logic required to
carry out operations like move, scale, and so forth.
AcGeMatrix3d m;
AcGeVector3d v(2.0, 4.0, 1.0); // X, Y, Z translation
m.setTranslation(v);
AcDbEntity* pEnt = ... // open entity to move
pEnt->transformBy(m);
pEnt->close();
"Anders Eriksson" wrote in message
news:[email protected]...
> // Anders
Message 7 of 11
Hello Tony!
On Tue, 25 Nov 2003 09:43:03 -0800, Tony Tanzillo wrote:
> AcGeMatrix3d m;
> pEnt->close();
Ok, I finally get it! The movement is relative, but what if I need to move
the entity to a specific coordinate?
I just tested your code on a line and it will change both start point and
end point. What if I only want to change the start point?
Thanks for helping!
// Anders
Message 8 of 11
Thanks, Tony.
Message 9 of 11
> need to move the entity to a specific coordinate?
The movement is still relative. The only difference is how you
determine the displacement.
I think you're missing the point, which is that you originally
suggested that moving an entity requires some specific knowledge
about its type (e.g., its a circle, a line, an arc or so on), and
that you must take different actions depending on the entity type,
and what I was trying to say is that this is not the case.
If you only want to change the start point, that is not
'moving' the entity, that's more akin to stretching it,
and that's a different subject 🙂
Message 10 of 11
Which you can't do if you haven't got the entities insertion point and to
get the insertion point you need to know the entity type.
Yes I see my error and I will update a lot of code using transformBy
instead of testing for all sorts of strange entity types...
Yes of cause!
Thank you very much! I have learnt something new and really valuable! I
really love newsgroups!!
// Anders
Message 11 of 11
"Anders Eriksson" skrev i
meddelandet
Try getting the first grip-point. That would work in many cases.
Good luck,
Henrik Vallgren
www.stream-space.com/links.htm
