getPointAtDist() to return a NON-Vertex point on the Polyline...
Hey guys,
I need to get the coordinates of a point on my polyline, which is at a specific distance from the start point of my polyline. When I use the getPointAtDist() function, it returns the closest vertex to that point which is apparently not what I want. Is there something wrong or is this function supposed to only return vertices?? I mean what if my distance does not have a vertex at??
If it is so I think I could add a vertex to my polyline by means of PEDIT command, but the problem to that is I can't give it a distance on the curve 😞
If you guys could please provide me a solution, I'd really really appreciate it 😞
Regards, Omid Manikhi
I just looked at the code for 2d, 3d, and lightweight polylines and they are
all coded to return points between vertices if that's where the distance
specifies. I don't know what's going on in your case to cause only vertex
points to be returned.
wrote in message news:[email protected]...
Hey guys,
a vertex at??
it 😞
Thank you very very much for your response and your effort. In fact you made me realize that the getPointAtDist functions, work as I expected they would. So I found out there was something wrong with my code. As far as I was using the point to draw a line, with the LINE command, I realized that it is obeying the OSNAP settings!, so it would snap the point at the nearest vertex. Instead I added the line to the database through an AcDbLine object, and it works now!
Thank you very very very much again Mr. Cooney.
