get windows version from inside ARX using GetVersionEx API function
gennadykhSSDP9
gennadykhSSDP9
I want to extract windows version calling GetVersionEx API function from inside my ARX. On Windows 10 i'm getting Windows 8 output: major version=6, minor version=2 which in accordance to msdn page it is correct: https://msdn.microsoft.com/en-us/library/windows/desktop/ms724833%28v=vs.85%29.aspx On the bottom of the same page there is a note that "application should be manifested for windows 10". Anybody can suggest how to do it for ARX which is actually DLL, not an EXE. Thanks in advance, Gennady
tbrammer
Maybe this comment to this CodeProject article can help you.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
gennadyKhkh
Yes, tbrammer, it works! Thank you very much! Gennady
gennadyKhkh
Dont see on this page close to that. Thanks, Gennady
gennadyKhkh
Never mind, tbrammer, found you actual email with such option
tbrammer
Smiley Happy
