Get name of pending commands
fehrsZBFB9
fehrsZBFB9
I'm looking for a way to get the name of a pending command. When  a command is started during user input, the user input is canceled. If the current command was left, the pending command will be started. I would like to detect the pending commands name inside the current running command without leaving it. I found acedIsInputPending to detect if there's a pending command. And I found acedEatCommandThroad to remove the pending command. Furthermore I found out that the queue for the pending commands is called command throat. Are there more functions to interact with the command throat?
Thanks in Advance,
Martin
tbrammer
You might try:
  • get the AutoCAD variable CMDNAMES with acedGetVar()
  • AcEditorReactor::commandWillStart() / commandEnded()/commandCancelled()/commandFailed()
You can test the AcEditorReactor using the command REACTORS -> Editor Reactor On [x]
from <ARX>\Samples\database\ArxDbg
I got the output below on the commandline. I first entered the command "_LINE" and started to draw lines,
then I entered 'CMDNAMES (with ' to start the command transparent) which internally starts the SETVAR command.
Befehl: _LINE
   [ED REACTOR] : [Command Will Start: LINE]
Ersten Punkt angeben:
Nächsten Punkt angeben oder [Zurück]: 'CMDNAMES
  [ED REACTOR] : [Command Will Start: SETVAR]
CMDNAMES = "LINE'SETVAR" (schreibgeschützt)
   [ED REACTOR] : [Command Ended: SETVAR]
Nehme LINIE-Befehl wieder auf.
   [ED REACTOR] : [Command Ended: LINE]
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
