Generate preview
Generate preview
Message 1 of 12
Generate preview
I'm trying using AcDbDatabase::thumbnailBitmap() and
AcDbDatabase::setThumbnailBitmap()
to generate a preview thumbnail on a new database before saving it, but it
fails on thumbnailBitmap().
Here is the code: (ObjectArx2002), no error checking
AcDbDatabase *pNewDB = NULL;//new database;
es = acdbHostApplicationServices()->workingDatabase()->wblock(pNewDB,
id);//add something to it
void * pThumbnail = pNewDB->thumbnailBitmap();//fails here
pNewDB->setThumbnailBitmap(pThumbnail);
The documentation is not very clear (or extensive) so i'm not sure i do the
right thing
TIA
alex
Replies (11)
Message 2 of 12
Hello Alex,
I don't know the answer. But I would try to
- save the database (at first with database->saveAs, if not work: second with Doc->Save)
- load the database
and then (in the hope, acad has created the thumbnail) try to access to the thumbnail.
Please see also the acad help:
Note These APIs are meant primarily for ObjectDBX developers. Preview thumbnail behavior reflect what the host application must do
to generate a preview.
For ObjectARX developers AutoCAD is taking care of all preview thumbnail generation. ObjectARX users should leave these APIs alone,
and allow AutoCAD behaviors to prevail.
doc snyder
"alex" schrieb im Newsbeitrag news:5146780@discussion.autodesk.com...
right thing
TIA
alex
Message 3 of 12
Hello doc snyder
From the docs:
Acad::ErrorStatus AcDbDatabase::saveAs(const char* fileName);
If the database executing the saveAs() function is not the current database
in the AutoCAD editor, then the thumbnail preview image is NOT saved to
fileName.
I don't need the thumbnail, I just want the db to be saved with a thumbnail,
for the next time someone opens it.
alex
"doc snyder" wrote in message
news:5147232@discussion.autodesk.com...
Hello Alex,
with Doc->Save)
- load the database
thumbnail.
doc snyder
right thing
TIA
alex
Message 4 of 12
How is it failing?
wblock() won't create a thumbnail in the database it is writing to, so
pNewDB->thumbnailBitmap() should return NULL.
"alex" wrote in message
right thing
TIA
alex
Message 5 of 12
Art:
It indeed returns NULL.
I am aware of the fact that wblock() doesn't create thumbnails, i'm just
looking for a way around it.
thanks
alex
"Art Cooney" wrote in message
news:5147493@discussion.autodesk.com...
How is it failing?
right thing
TIA
alex
Message 6 of 12
If you're aware that it returns NULL, then what do you mean by it "fails"?
There isn't any way to get wblock to create a thumbnail. The thumbnail is
generated by our graphics system and requires that the drawing be loaded in
the AutoCAD editor. The only way to get AutoCAD to put a thumbnail in the
drawing created by the wblock would be to open that drawing in the AutoCAD
editor and then save it.
news:5148244@discussion.autodesk.com...
Art:
thanks
alex
How is it failing?
right thing
TIA
alex
Message 7 of 12
The logical conclusion for me is
not create a database before wblock but
let your function do all what the user makes with the drawing...
- to create a new document
- wblock the wished entities from source document
- set document to current (or active?)
- zoom (all or limits), optionally shade the dwg
- and save the dwg temporary
But the programmer not wish a mdi child, which popups in the meantime.
Here ends my hope to find a nice (acceptable) solution.
doc snyder
"Art Cooney" schrieb im Newsbeitrag news:5148272@discussion.autodesk.com...
Art:
thanks
alex
How is it failing?
right thing
TIA
alex
Message 8 of 12
typedef Acad::ErrorStatus
(*acdbMakeDrawingPreviewPtr)
(AcDbDatabase* pDb, bool bUnused);
Acad::ErrorStatus MakeThumbnail(AcDbDatabase* pDb)
static acdbMakeDrawingPreviewPtr pFunc = NULL;
if( pFunc == NULL )
HMODULE hLib = GetArxModuleHandle("AcBlock.arx");
if( hLib == NULL )
return Acad::eInvalidInput;
void* pv = ::GetProcAddress(hLib,
"acdbMakeDrawingPreview");
if( pv == NULL )
pFunc = (acdbMakeDrawingPreviewPtr) pv;
if( pDb == NULL )
return (*pFunc)(pDb, false);
// moduleName (filename.arx) must be on PATH.
HMODULE GetArxModuleHandle(const char* moduleName)
HMODULE hLib = ::GetModuleHandle(moduleName);
if( hLib == NULL )
acrxLoadModule(moduleName, false, false);
return hLib;
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"alex" wrote in message news:5148244@discussion.autodesk.com...
Art:
thanks
alex
How is it failing?
right thing
TIA
alex
Message 9 of 12
Art:
I just meant it fails for me. I didn't understand it works just for the
current db.
Do you have any comment to Tony's post of today?
alex
Art:
thanks
alex
How is it failing?
right thing
TIA
alex
Message 10 of 12
Tony:
Just what i was looking for.
If I understand you right, it's a (undocumented?) function exported by
AcBlock.arx
I just tried it on a ACAD2000, works OK. It looks just like what wblock
command does - thumbnailwise, including 'low quality' thumbnail.
It seems the GS has to 'see' it on the screen to do it right.
Does it work in 2006, 2007?.
alex
"Tony Tanzillo" wrote in message
news:5149046@discussion.autodesk.com...
if( pFunc == NULL )
if( hLib == NULL )
if( pv == NULL )
if( pDb == NULL )
if( hLib == NULL )
return hLib;
Art:
thanks
alex
How is it failing?
right thing
TIA
alex
Message 11 of 12
All that I can say is use undocumented functions at your own risk because
they can change or go away.
news:5149048@discussion.autodesk.com...
Art:
current db.
alex
Art:
thanks
alex
How is it failing?
right thing
TIA
alex
Message 12 of 12
>> at your own risk because they can change or go away.
Perhaps one reason we tend to rely on undocumented
APIs is because the above statement seems to apply
to documented APIs and their behavior as well.
For example, the way selection set ordering changed
in 2005, broke thousands of scripts that relied on the
previous behavior (selection set order == picked order).
IOW, when it comes to having the rug yanked out from
beneath us, it does not seem to matter much if it was
documented, or not.
