fatal error C1083: Cannot open include file: 'type_traits': No such
Message 1 of 20
Hi
I am trying to compile the provided sample ARXDBG after installing ObjectARX 2010. But gettings the following error:
fatal error C1083: Cannot open include file: 'type_traits': No such file or directory c:\objectarx 2010\inc\acarray.h 93 ArxDbg
Here is my configurations:
OS: Windows vista 32 bit.
IDE: Microsoft visual studio 2008.
Advance thanks for any feedback..
thx
Rashidul
Replies (19)
Message 2 of 20
You need to download and install the Service Pack for VS 2008.
Joe
wrote in message news:6230548@discussion.autodesk.com...
Hi
thx
Rashidul
Message 3 of 20
Hi Joe
Thanks a lot. The problem is solved by installing SP but now its showing another series of problem.
First it showed
"Error 1 fatal error LNK1104: cannot open file 'acdb17.lib' Library Library"
I downloaded the library file from internet. Then it is again showing error:
"Error 1 fatal error LNK1104: cannot open file 'acge17.lib' Library Library"
Its quite absurd situation.
Can you/anyone help in this issue?
Thx
Rashidul
Message 4 of 20
Rashidul,
I'm assuming (by the compiler) that you are trying to develop for AutoCAD
2010. The libraries for 2010 should be "18" instead of "17" ... acdb17.lib
should be acdb18.lib, etc. Make sure that the ObjectARX libraries for 2010
are installed and that you have added their path to either the global
compiler settings or the project settings. Then give it a go.
Joe
wrote in message news:6230714@discussion.autodesk.com...
Hi Joe
First it showed
Thx
Rashidul
Message 5 of 20
Joe
Thanks a lot for very quick response.
You are correct that I am trying to develop for Autocad 2010 and also I have installed ObjectARX and
set the path for project settings as follows:
Project -> Library properties-> Then
Left pane: C/C++
Right pane: Additional Include directories: [A folder contains the header files taken from
ObjectARX installation dir\ObjectARX 2010\inc
+ ObjectARX installation dir\ObjectARX 2010\inc-win32]
Left pane: Linker
Right pane: Additional library directories: [A folder contains the libraries taken from ObjectARX installation dir\ObjectARX 2010\lib-win32]
Did I do any mistake? Do you find any clue from here..?
Thx
Rashidul
Message 6 of 20
Those are correct. Now under your project properties -> Linker -> Input,
change any libraries with "17" in them to "18" in the Additional
Dependencies (acdb18.lib acge18.lib). Then it should link with no errors.
Joe
wrote in message news:6230932@discussion.autodesk.com...
Joe
Left pane: C/C++
files taken from
Left pane: Linker
Thx
Rashidul
Message 7 of 20
Rashidul:
Just open the .sln file that gets installed with the ObjectARX 2010 SDK,
then build it. You do not need to change or add any settings; the file is
designed to build as-is when you open it from its installed location. 🙂
Owen Wengerd
President, ManuSoft <>
VP Americas, CADLock, Inc. <>
Message 8 of 20
Hi Joe
I did the changes from 17 to 18 but it didn't help anymore...
I think there was a unintentional misconduct in the series of post/reply. Now I like to clarify it.
I had a application for Autocad 2008. Now it expected to make it compatible for Autocad 2010.
Thats why I tried to do so.
First I installed ObjectARX 2010 and tried to compile the application in VS 2008. But showed the errors as specified before 'type_traits':.
So I tried to compile the sample ARXDBG and got the same errors. Then I installed Service pack which solved the problem for sample
but not for my application that showed other errors.
Error 1 fatal error C1189: #error : _WIN32_WINNT settings conflicts with _WIN32_IE setting c:\program files\microsoft sdks\windows\v6.0a\include\sdkddkver.h 217 Library
Error 2 error BK1506 : cannot open file '.\R2007\Debug\STDAFX.sbr': No such file or directory BSCMAKE Library
Then one of my colleage asked to add StdAfx.h file in library folder and change there
#define WINVER 0x400
to
#define WINVER 0x500
Then it showed other fatal errors/can't open files ('acdb17.lib' .....) . After downloading one after another file it goes to a endless series of errors.
So I don't understand what should be the next step. As it was working smoothly for Autocad 2008 so its logical to
to also work with Autocad 2010 by putting the lib/inc files. But wondering why not working !!!
* If you think you can help me to compile by taking the source from me then I can send it to you.
Regards
Rashidul
Message 9 of 20
Hi Owen
You are right about the sample. But I am having problem with my own application
which is working for Autocad 2008 but having problem to compile with ObjectARX 2010.
I have stated the complete history in the last reply of Joe. Hope you can get some clue from there.
Regards
Rashidul
Message 10 of 20
Rashidul,
If you want to email me your entire project, I'll take a look at the
"acdb17.lib" problem.
Joe
wrote in message news:6231330@discussion.autodesk.com...
Hi Joe
for Autocad 2010.
change there
to
errors.
why not working !!!
Regards
Rashidul
Message 11 of 20
Hi Joe
Can you plz give me your email address?
I like to give you the fresh copy of source that is working with Autocad 2008. Then I think it
will be easier for you to debug because I have tried with different ways in different times and the
current error is different than lib17 problem. If I can generate this error again then I will also send
you that version. In the mean time if you have time then shortly you can have a try with fresh code
with your expert hand.
Thx
Rashidul
Message 12 of 20
Rashidul,
Just reply to me here instead of the group ...
Joe
wrote in message news:6231567@discussion.autodesk.com...
Hi Joe
Thx
Rashidul
Message 13 of 20
Hi Joe
Here is the source code attached as zip. I didn't attached the libraries.
Have success !!
Thx
Rashidul
Message 14 of 20
Rashidul,
This source code is not complete. It couldn't have been compiled even for
AutoCAD 2008. There is no Class definition (header file) for
"ESC_SlideLibrary". The implementation is there but it won't compile
without the header file. The project is referencing the right libraries
(acdb18.lib, etc) so I'm not sure what you were seeing or even how you got
to the linker.
Joe
wrote in message news:6231849@discussion.autodesk.com...
Hi Joe
Have success !!
Thx
Rashidul
Message 15 of 20
Hi Joe
Sorry for bothering you.
Actually I am new in this project. This developed by someone else in my company and that is working already in production.
Now it is desired to make it compatible with Autocad 2010 and given the source code. As it is ensured that this workable with 2008
so I didn't try to compile with 2008. So I will try myself to compile with 2008 first. Then I will let you know...
One more thing:
I am not clear about "ESC_SlideLibrary" but
I have removed some files which are much bigger in size thinking that those are unnecessary like LIBRARY.ncb and R2007 directory (attachment shows the list of files in a image). Do you think these are necessary?
And including these exceeds max allowable size for attachment. So I could send you those files.
I am really grateful to you for spending a lot of your valuable time for me.
Thx
Rashidul
Message 16 of 20
Hi Joe
I have fixed that problem by following this link.
http://discussion.autodesk.com/forums/thread.jspa?messageID=6233162᱊
But now its shows another error and that is
error LNK2001: unresolved external symbol _SetacrxPtp
Here is my definition file content
EXPORTS
acrxEntryPoint
_SetacrxPtp
acrxGetApiVersion
Do you have any idea about it?
Thx
Rashidul
Message 17 of 20
Just remove that line from your definition file.
Joe
wrote in message news:6233164@discussion.autodesk.com...
Hi Joe
EXPORTS
acrxEntryPoint
_SetacrxPtp
acrxGetApiVersion
Thx
Rashidul
Message 18 of 20
Hi Joe
Thanks for your quick reply.
But that line was also in our previous working version. But I don't know more anything about that because
the developers are not here in my company now. I guess it may refer to any dll/library, any idea?
I had tried by removing that line and then it compiled successfully. But when I was trying to load the arx file in
Autocad (Map 3D 2009) then it fails with error stating.
Lib2010.arx is incompatible with this version of AutoCAD.
Thats why I guess that definition might be necessary...
Any clue in overall?
Thx
Rashidul
Message 19 of 20
Rashidul,
I think the SetAcrxPtp was for older versions of AutoCAD. It's not required
here (maybe someone else knows more about this). Is Lib2010.arx the file
that you compiled? Which AutoCAD version was it compiled for. Which
compiler did you use (VS2005 or VS2008)? Judging by the name, it was
compiled for AutoCAD 2010. If this is the case, it will not load in any
version below 2010 (Map 2009).
Joe
wrote in message news:6233305@discussion.autodesk.com...
Hi Joe
Thx
Rashidul
Message 20 of 20
Hi Joe
Thanks for your valuable feedbacks and important suggestions.
At last the problem is solved and indeed it seems 'SetAcrxPtp'
was for previous version of ObjectARX. Because now without this
export statements I have compiled the application and got the
functions in Autocad 2010. You are also correct it doesn't work
in Map 2009.
Keep it up to contribute in forum...
Thanks a lot again...
Regards
Rashidul
