Exporting to JSON
Exporting to JSON
Exporting to JSON
I want to export all the information that i am printing on Autocad console to a json file.
I have gone through the spotify, nholmann,s code. But those are not working.
As i am working in c++ on my plugin, i want to export the data to json.
Please help
tbrammer
I'm not sure whether I fully understand what you want to do.
Do you want to write everything that you write to the text screen with acutPrintf(...) into a JSON file?
You could try to redefine acutPrintf() as a variadic macro, that formats the string with acutSPrintf(ACHAR *buffer, ...), than calls acutPrintf(L"%s", buffer)and finally writes buffer into your JSON file.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Yes, initially i want to do exactly what you said.
But i was thinking that i need to include some json libraries first or some include directories for exporting everything to json.
Is your solution create a new json file and put all my text into that? Or it is totally a different method.
I want to know as i am stuck in this exporting problem.
tbrammer
There is no JSON API in ObjectARX.  You could either simply write the strings in JSON format using basic C++ I/O functions and do the formatting yourself, or you can use any available JSON C++ lib that suit your needs.
It depends on your needs how you manage to create the JSON output. Let's say in your ARX you call
acutPrintf(L"My first line");
acutPrintf(L"My second line");
and you want your JSON to look like this:
{ "TextScreen": [ ""
,"My first line"
,"My second line"
To make sure that you get a valid JSON:
  • your output needs a "header line" like the above line   { "TextScreen": [ ""
  • you have to comma-separate the strings in each output from acutPrintf(). No comma after last entry!
  • you have to make sure that you add a "footer line" like the line       ])  to terminate your JSON.
    Ask yourself at which point you need the proper termination line.
  • Take care with special characters. I.e. newline (\n) should be replaced by L"\\n".
