Error with Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
hi!
I'm using ObjectARX. When compiling this line in VS 2010 Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager I get an exception of type System.InvalidProgramException, "Common language program found invalid."
Why is this? Any solution?
Thank you ...
philippe.leefsma
Hi
Sorry, that's clearly not enough information to be able to make any suggestion, you should either post a bigger code sample or provide more context. This doesn't look like a familiar exception, did you check on the web what might be the reasons?
You mention you are using ObjectARX but that line of code is .Net API, so you should post a case on the .Net part of that forum. Also I assume you probably mean the exception is generated when you run the code, not when you compile it. Mentionning exactly which version of AutoCAD you are running can help as well.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
