error C2440: '=' : cannot convert from 'char *' to 'ACHAR *'
DWhiteley
Advisor Advisor
DWhiteley
Guys,
I'm converting an old C++ project to ObjectARX 2013 & then on later to 2016 from 2004. (i'm assuming Visual Teefy might help me out in 2013).
This bit of code has got me stuck:
#define START_STR(rb,str) rb = ads_newrb(RTSTR);rb->resval.rstring = cpCopystr(str)
 START_STR(rbMake, _COPY);
I'm getting this error:
Error 5 error C2440: '=' : cannot convert from 'char *' to 'ACHAR *'
I'm assuming it's because of the UNICODE changes.
Can anyone help me out on this please?
Dave
Alexander.Rivilis
You have to provide code of cpCopystr. I think this function have to return ACHAR * instead of char *
Also you have to use in code:
START_STR(rbMake, L"_COPY");
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
DWhiteley
Here you go:
char *
cpCopystr(char *str)
char *temp;
temp = (char *)malloc((unsigned) (strlen(str) + 1));
if (temp == NULL) {
#ifdef NON_ADS
printf("Out of memory in cpCopystr()");
abort();
#else
acrx_abort("Out of memory in cpCopystr()");
#endif
strcpy(temp, str);
return(temp);
Regards
Dave
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Alexander.Rivilis
What about next code:
#define START_STR(rb,str) (rb = acutBuildList(RTSTR, str))
resbuf *rbStart = NULL;
START_STR(rbStart, L"_COPY");
P.S.: I do not know what is _COPY in your code.  I hope it is a string like "_COPY"
Expert Elite Member
DWhiteley
Hi Alexander,
_COPY is defined as:
#define _COPY          "_.COPY\0"
do I need to alter this to  _T("_.COPY\0") ?
Dave
Alexander.Rivilis
@Anonymous wrote:
...do I need to alter this to  _T("_.COPY\0") ?
Yes. Or L"_.COPY\0"
Expert Elite Member
