Message 1 of 1
Dynamic block count - Using Visibility
02:40 AM
I'm trying count my dynamic block's using C# and .net but so far I can't seem to figure how to do it.
With this code :
[CommandMethod("DBP")] static public void DynamicBlockProps() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; PromptStringOptions pso = new PromptStringOptions( "\nEnter dynamic block name or enter to select: " ); pso.AllowSpaces = true; PromptResult pr = ed.GetString(pso); if (pr.Status != PromptStatus.OK) return; Transaction tr = db.TransactionManager.StartTransaction(); using (tr) { BlockReference br = null; // If a null string was entered allow entity selection if (pr.StringResult == "") { // Select a block reference PromptEntityOptions peo = new PromptEntityOptions( "\nSelect dynamic block reference: " ); peo.SetRejectMessage("\nEntity is not a block."); peo.AddAllowedClass(typeof(BlockReference), false); PromptEntityResult per = ed.GetEntity(peo); if (per.Status != PromptStatus.OK) return; // Access the selected block reference br = tr.GetObject( per.ObjectId, OpenMode.ForRead ) as BlockReference; } else { // Otherwise we look up the block by name BlockTable bt = tr.GetObject( db.BlockTableId, OpenMode.ForRead) as BlockTable; if (!bt.Has(pr.StringResult)) { ed.WriteMessage( "\nBlock \"" + pr.StringResult + "\" does not exist." ); return; } // Create a new block reference referring to the block br = new BlockReference( new Point3d(), bt[pr.StringResult] ); } BlockTableRecord btr = (BlockTableRecord)tr.GetObject( br.DynamicBlockTableRecord, OpenMode.ForRead ); // Call our function to display the block properties DisplayDynBlockProperties(ed, br, btr.Name); // Committing is cheaper than aborting tr.Commit(); } } private static void DisplayDynBlockProperties( Editor ed, BlockReference br, string name ) { // Only continue is we have a valid dynamic block if (br != null && br.IsDynamicBlock) { ed.WriteMessage( "\nDynamic properties for \"{0}\"\n", name ); // Get the dynamic block's property collection DynamicBlockReferencePropertyCollection pc = br.DynamicBlockReferencePropertyCollection; // Loop through, getting the info for each property foreach (DynamicBlockReferenceProperty prop in pc) { // Start with the property name, type and description List<string> activeVisibility = new List<string>(); if(prop.PropertyName == "Choisir") { ed.WriteMessage("\nProperty Type Code : " + prop.PropertyTypeCode.ToString()); ed.WriteMessage("\nProperty Value : " + prop.Value.ToString()); ed.WriteMessage("\nProperty UnitsType : " + prop.UnitsType.ToString()); } } } }
The code was found on DevBlog.
I can get to the properties, but the position of properties change from block to block.
What I would like it either get the Visibilty or the right lookup.
Anyone have suggestions for me?
regards, Frank
