Dynamic block count - Using Visibility
Message 1 of 1
I'm trying count my dynamic block's using C# and .net but so far I can't seem to figure how to do it.
With this code :
 [CommandMethod("DBP")]
        static public void DynamicBlockProps()
            Document doc =
              Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptStringOptions pso =
              new PromptStringOptions(
                "\nEnter dynamic block name or enter to select: "
            pso.AllowSpaces = true;
            PromptResult pr = ed.GetString(pso);
            if (pr.Status != PromptStatus.OK)
                return;
            Transaction tr =
              db.TransactionManager.StartTransaction();
            using (tr)
                BlockReference br = null;
                // If a null string was entered allow entity selection
                if (pr.StringResult == "")
                    // Select a block reference
                    PromptEntityOptions peo =
                      new PromptEntityOptions(
                        "\nSelect dynamic block reference: "
                    peo.SetRejectMessage("\nEntity is not a block.");
                    peo.AddAllowedClass(typeof(BlockReference), false);
                    PromptEntityResult per =
                      ed.GetEntity(peo);
                    if (per.Status != PromptStatus.OK)
                        return;
                    // Access the selected block reference
                    br =
                      tr.GetObject(
                        per.ObjectId,
                        OpenMode.ForRead
                      ) as BlockReference;
                else
                    // Otherwise we look up the block by name
                    BlockTable bt =
                      tr.GetObject(
                        db.BlockTableId,
                        OpenMode.ForRead) as BlockTable;
                    if (!bt.Has(pr.StringResult))
                        ed.WriteMessage(
                          "\nBlock \"" + pr.StringResult + "\" does not exist."
                        return;
                    // Create a new block reference referring to the block
                    br =
                      new BlockReference(
                        new Point3d(),
                        bt[pr.StringResult]
                BlockTableRecord btr =
                  (BlockTableRecord)tr.GetObject(
                    br.DynamicBlockTableRecord,
                    OpenMode.ForRead
                // Call our function to display the block properties
                DisplayDynBlockProperties(ed, br, btr.Name);
                // Committing is cheaper than aborting
                tr.Commit();
        private static void DisplayDynBlockProperties(
          Editor ed, BlockReference br, string name
            // Only continue is we have a valid dynamic block
            if (br != null && br.IsDynamicBlock)
                ed.WriteMessage(
                  "\nDynamic properties for \"{0}\"\n",
                  name
                // Get the dynamic block's property collection
                DynamicBlockReferencePropertyCollection pc =
                  br.DynamicBlockReferencePropertyCollection;
                // Loop through, getting the info for each property
                foreach (DynamicBlockReferenceProperty prop in pc)
                    // Start with the property name, type and description
                    List<string> activeVisibility = new List<string>();
                    if(prop.PropertyName == "Choisir")
                        ed.WriteMessage("\nProperty Type Code : " + prop.PropertyTypeCode.ToString());
                        ed.WriteMessage("\nProperty Value : " + prop.Value.ToString());
                        ed.WriteMessage("\nProperty UnitsType : " + prop.UnitsType.ToString());
The code was found on DevBlog.
I can get to the properties, but the position of properties change from block to block.
What I would like it either get the Visibilty or the right lookup.
Anyone have suggestions for me?
regards, Frank
Replies (0)
