dwgOutFields - filing out pointer to custom class
christineweiss86
christineweiss86
Hello everyone,
I have another issue filing out data of my custom entities.
So I have a custom entity deriving from AcDbBlockReference that saves a pointer to another custom class that derives from AcDbCurve and two enum classes (lage and FmaArt).
class DLLIMPEXP PProFmaKomponente : public AcDbBlockReference {
protected:
	 static Adesk::UInt32 kCurrentVersionNumber ;
private:
	 PProGeoKante* m_pGeo;
lage m_lage;
FmaArt m_fmaArt; (...) //----- AcDbObject protocols //- Dwg Filing protocol virtual Acad::ErrorStatus dwgOutFields (AcDbDwgFiler *pFiler) const ; virtual Acad::ErrorStatus dwgInFields (AcDbDwgFiler *pFiler) ; //- Dxf Filing protocol virtual Acad::ErrorStatus dxfOutFields (AcDbDxfFiler *pFiler) const ; virtual Acad::ErrorStatus dxfInFields (AcDbDxfFiler *pFiler) ; //----- AcDbEntity protocols //- Graphics protocol protected: virtual Adesk::Boolean subWorldDraw (AcGiWorldDraw *mode) ; (...) } ;
Now I am trying to file out these pointers using the following code and it crashes.
Acad::ErrorStatus PProFmaKomponente::dwgOutFields (AcDbDwgFiler *pFiler) const {
	 assertReadEnabled () ;
	 //----- Save parent class information first.
	 Acad::ErrorStatus es =AcDbBlockReference::dwgOutFields (pFiler) ;
	 if ( es != Acad::eOk )
		  return (es) ;
	 //----- Object version number needs to be saved first
	 if ( (es =pFiler->writeUInt32 (PProFmaKomponente::kCurrentVersionNumber)) != Acad::eOk )
		  return (es) ;
	 //----- Output params
	 pFiler->writeAddress(m_pGeo);
	 pFiler->writeAddress(&m_lage);
	 pFiler->writeAddress(&m_fmaArt);
	 return (pFiler->filerStatus ()) ;
so my questions are now:
1) can you even file out custom datatypes like enum classes and custom classes?
2) if you can do it how does it work?
for enums use something like this:
template<class _Ty>
inline
Acad::ErrorStatus dwgReadEnum(AcDbDwgFiler* filer, _Ty & Other)
  assert(sizeof(_Ty) <= sizeof(Adesk::Int32));
  Adesk::Int32 iOther(0);
  filer->readInt32(&iOther);
  Other = static_cast<_Ty>(iOther);
 return filer->filerStatus();
template<class _Ty>
inline
Acad::ErrorStatus dwgWriteEnum(AcDbDwgFiler* filer, _Ty Other)
  filer->writeInt32(static_cast<Adesk::Int32>(Other));
for custom subclasses each subclass needs its own dwgIn/dwgOut function
m_pGeo->dwgOutFields(filer)
HTH
Arnold
Hi!
You shouldn't use writeAddress.
For saving/restoring enums - use writeInt32/readInt32 (ie, as in reply above).
For saving/restoring "pointer" to your custom object - you should write/read it objectId.
If your custom object (PProGeoKante) is not added to acad database and have not objectId, then you should write/read it field by field.
