Determine if the point is inside closed curve
majklha
Message 1 of 12
majklha
I have AcGeCurve2d or AcDbCurve2d and AcGePoint2d. They are closed. How I determine, if the point is inside the curve?
I know mathematical methods for it, but, do Autocad classes have some easier build-in function?
Accepted solutions (3)
Replies (11)
Message 2 of 12
tbrammer
As far as I know there is no such function that you can use directly.
But it is easy to write a function that uses the "Ray casting algorithm" with class AcGeCurveCurveInt2d
  1. Construct an AcGeRay2d ray(pt,v); with the point pt you want to test. The direction  is arbitrary.
  2. Construct an AcGeCurveCurveInt2d sect(ray, curve); object with your AcGeCurve2d and the ray.
  3. int count = sect.numIntPoints(); is the number of intersection points.
  4. Determine the number of intersections on which the ray's path does not change from one side of curve to the other side. See below.
  5. If (count-n) it is odd pt is inside curve. If it is even the point is outside curve.
For step 4 you can use
AcGeCurveCurveInt2d::getIntConfigs(
	int intNum,
	AcGe::AcGeXConfig& config1wrt2,
	AcGe::AcGeXConfig& config2wrt1
) const;
to analyze whether the ray's path changes from one side of the curve to the other side at each section point.
If you happen to find an AcGeXConfig of kind kOverlapXXX or kXXXOverlap you could either retry with a different ray direction vector v or check the previous/next sectionpoint.
I think you can even get a direct result if you add the results of the function below using the xcfg values of the ray:
int CountLR(AcGe::AcGeXConfig xcfg)
	switch (xcfg)
		case AcGe::kLeftRight:     return  2;
		case AcGe::kRightLeft:     return -2;
		case AcGe::kLeftLeft:      return  0;
		case AcGe::kRightRight:    return  0;
		case AcGe::kLeftOverlap:   return  1;
		case AcGe::kOverlapLeft:   return -1;
		case AcGe::kRightOverlap:  return -1;
		case AcGe::kOverlapRight:  return  1;
		case AcGe::kOverlapOverlap:return  0;
		// not sure about these:
		case AcGe::kOverlapStart:  return  0;
		case AcGe::kOverlapEnd:    return  0;
		case AcGe::kPointLeft:     return -1;
		case AcGe::kPointRight:    return  1;
		case AcGe::kNotDefined:    return  0;
		case AcGe::kUnknown:       return  0;
The sum could be
  • -2  => pt is inside. curve runs clockwise.
  • -1 => pt is on curvecurve runs clockwise.
  • 0 => pt is outside curve. curve may be cw or ccw.
  • 1 => pt is on curvecurve runs counter clockwise.
  • 2  => pt is inside. curve runs counter clockwise.
  • Other values: Something went wrong or curve is self-intersecting and winds multiple times around pt.
I didn't try this myself yet and would be interested if someone uses this method. Please comment!
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 12
majklha
Thanks, I seems usable, I an going to try it. But I got stuck immediately on start - I am not able to transfer polyline or spline to AcGeCurve2d.
I select in drawing eg. polyline - AcDbPolyline, the child of the AcDCurve. But AcDbCurve has method only to transfer to AcGeCurve3d.... And AcGeCurve3d is virtual, we must use AcGeSpline3d.....and I dont know hoe to trasfer AcGeSpline3d to AcGeSpline2d....
And with Ray (I wanted to check it first with user-defined ray) is the same problem: AcDbRay-AcDbCurve->AcGeCurve3d...
Maybe it is the basic knowlege, I am sorry for that easy question.
Message 4 of 12
majklha
Problem with ray I solved
	AcGePoint3d ptRay;
	pRay->getStartPoint(ptRay);
	AcGeRay2d geRay(asPnt2d(ptRay), asVec2d(pRay->unitDir()));
Message 5 of 12
Alexander.Rivilis
Other method with using AcDbMPolygon class:
enum PointContourStatus {
  OutsideContour  = -1,
  OnContour       =  0,
  InsideContour   =  1,
  InternalError   = -99
PointContourStatus is_point_in_curve(AcGePoint3d p, AcGePoint2dArray &pts, AcGeDoubleArray &blgs)
  AcDbMPolygon mpol;
  if (mpol.appendMPolygonLoop(pts,blgs) != Acad::eOk) return InternalError;
  AcGeIntArray ar;
  if (mpol.isPointOnLoopBoundary(p,0)) return OnContour;
  if (mpol.isPointInsideMPolygon(p,ar) > 0) return InsideContour;
  else return OutsideContour;
PointContourStatus is_point_in_curve(AcGePoint3d p, AcDbCurve *pCurv)
  double fuzz = AcGeContext::gTol.equalPoint();
  AcGePoint3d pointOnCurve;
  pCurv->getClosestPointTo(p,pointOnCurve);
  if (p.distanceTo(pointOnCurve) <= fuzz) return OnContour;
  AcDbPolyline   *pPoly   = AcDbPolyline::cast(pCurv);
  AcDb2dPolyline *p2Poly  = AcDb2dPolyline::cast(pCurv);
  AcDbCircle     *pCircle = AcDbCircle::cast(pCurv);
  AcDbMPolygon mpol;
  if (pPoly) {
    if (mpol.appendLoopFromBoundary(pPoly)   != Acad::eOk) return InternalError;
  } else if (p2Poly) {
    if (mpol.appendLoopFromBoundary(p2Poly)  != Acad::eOk) return InternalError;
  } else if (pCircle) {
    if (mpol.appendLoopFromBoundary(pCircle) != Acad::eOk) return InternalError;
  } else return InternalError;
  AcGeIntArray ar;
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 6 of 12
majklha
It seems to be easier, but not applicable for spline and other "strange" curves.
Maybe it will be quicker.
For me it is sufficient. I need it for cadastral plots.
I am going to test both. Thanks.
Message 7 of 12
Alexander.Rivilis
For any other type of AcDbCurve you can:
1) use AcDbCurve::getAcGeCurve method to get AcGeCurve3d
2) use AcGeCurve3d::getSamplePoints  to get points for curve approximation
3) convert AcGePoint3dArray to AcGePoint2dArray
4) use is_point_in_curve(AcGePoint3d p, AcGePoint2dArray &pts, AcGeDoubleArray &blgs) method
Expert Elite Member
Message 8 of 12
tbrammer
If you are using a polygon build of sample points instead of "real curves" I would advice to use the "Winding number algorithm" and calculate subtended angles which is very easy and effective to implement for polygons.
To create an AcGeCurve from a polyline:
In case of an AcDbPolyline that consists of lines and arcs only you can construct an AcGeCompositeCurve2d that consists of AcGeCircArc2d and AcGeLine2d elements.
For an exact spline curve you can try this:
1) AcDbCurve::getSpline(AcDbSpline*& spline) const;
2) AcDbSpline::getNurbsData(int& degree, Adesk::Boolean& rational,
  Adesk::Boolean& closed, Adesk::Boolean& periodic,
  AcGePoint3dArray& controlPoints, AcGeDoubleArray& knots,
  AcGeDoubleArray& weights, double& controlPtTol, double& knotTol
3) Convert AcGePoint3dArray controlPoints to AcGePointdArray cntrlPnts
4) construct a AcGeNurbCurve2d with
AcGeNurbCurve2d nurb(int degree,
const AcGeKnotVector& knots, const AcGePoint2dArray& cntrlPnts,
const AcGeDoubleArray& weights, Adesk::Boolean isPeriodic
5) Set open/closed/rational:
if (closed)
   nurb.makeClosed();
else
  nurb.makeOpen();
if (rational)
  nurb.makeRational();
Message 9 of 12
majklha
You must include "dbMPolygon.h" and link "AcMPolygonObj.lib"
Message 10 of 12
Alexander.Rivilis
Yes of course.
Expert Elite Member
Message 11 of 12
majklha
And bulges is diametr of circle part of polygon? And for lines it expected "0"?
Message 12 of 12
Alexander.Rivilis
 For straight segment bulge equal 0 (if bulge < 1e-6 segment is straight)
Expert Elite Member
