DDX Problem in MFC Dialog
Kyudos
Advisor Advisor
Kyudos
We have a custom DDX function for values in the  MFC dialogs of our ARX. In ACAD 2018 calling CDataExchange::Fail in that function causes ACAD to crash.
I worked around it by adding a try...catch around the DDX function (it catches an 'unknown' error), so from that point of view I'm OK.
But, has anyone else experienced this? Or know why it might be happening? In this instance I was using DDX outside of the dialog DoDataExchange function - might that be an issue?
moogalm
Autodesk Support
Autodesk Support
As always I need a sample project that I can reproduce the behavior, I don't know your custom DDX implementation,  or what validation of input is going there.
Put a break point in
 "%VCINSTALLDIR%\Tools\MSVC\14.14.26428\atlmfc\src\mfc\dlgdata.cpp"
and check for call stack.
void CDataExchange::Fail()
	if (!m_bSaveAndValidate)
		TRACE(traceAppMsg, 0, "Warning: CDataExchange::Fail called when not validating.\n");
		// throw the exception anyway
	else if (m_idLastControl != NULL)
		// restore focus and selection to offending field
		HWND hWndLastControl;
		m_pDlgWnd->GetDlgItem(m_idLastControl, &hWndLastControl);
		if (hWndLastControl != NULL)
			::SetFocus(hWndLastControl);
			if (m_bEditLastControl) // select edit item
				::SendMessage(hWndLastControl, EM_SETSEL, 0, -1);
	else
		TRACE(traceAppMsg, 0, "Error: fail validation with no control to restore focus to.\n");
		// do nothing more
	AfxThrowUserException();
Kyudos
I re-coded to avoid calling  CDataExchange:: Fail outside of DoDataExchange... seems to have done the trick.
