Custom Entity Jig
Custom Entity Jig
daniel_gearloose
Custom Entity Jig
daniel_gearloose
Why do i get these Errors?
Jig.h file
#pragma once
class CCircleJig : public AcEdJig
public:
CCircleJig();
virtual ~CCircleJig();
virtual Adesk::Boolean update() override;
virtual DragStatus sampler() override;
virtual AcDbEntity* entity() const override { return m_pCircle; }
AcEdJig::DragStatus start();
protected:
enum stage
radius,
center
stage m_Stage;
AcGePoint3d m_PntPrev;
cxDbEmbeddedEntity* m_pCircle;
//double m_Radius;
void CreateCircle();
Jig.cpp file
#include "StdAfx.h"
#include "PointJig.h"
#include "..\EmbeddedEntity\xDbEmbeddedEntity.h"
CCircleJig::CCircleJig() : m_Stage(center)
	m_pCircle = new AcDbPoint(AcGePoint3d::kOrigin);
CCircleJig::~CCircleJig()
Adesk::Boolean CCircleJig::update()
	if (m_pCircle == NULL)
		return false;
	switch (m_Stage)
	case center:
		//m_pCircle->setRadius(m_Radius);
		m_pCircle->setCenter(m_PntPrev);
		break;
	default:
		return false;
	return true;
AcEdJig::DragStatus CCircleJig::sampler()
	setUserInputControls((UserInputControls)(AcEdJig::kAccept3dCoordinates | AcEdJig::kNullResponseAccepted));
	DragStatus sts;
	AcGePoint3d pntTemp;
	if (m_Stage == center)
		sts = acquirePoint(pntTemp, m_pCircle->position());
	else
		sts = acquirePoint(pntTemp);
	if (sts == AcEdJig::kNormal)
		if (pntTemp.isEqualTo(m_PntPrev))
			sts = kNoChange;
		m_PntPrev = pntTemp;
	return sts;
AcEdJig::DragStatus  CCircleJig::start()
	CString sPrompt;
	m_Stage = center;
	//acedGetReal(L"\nDurchmesser: ", &m_Radius);
	//m_Radius = m_Radius / 2;
	sPrompt = _T("\nMittelpunkt: ");
	setDispPrompt(sPrompt);
	AcEdJig::DragStatus sts = drag();
	if (sts != kNormal)
		return sts;
	if (sts == kNormal)
		AcDbObjectId idCircle = append();
	return sts;
void CreateCircle()
	CCircleJig circleJig;
	circleJig.start();
Alexander.Rivilis
Try to change:
with:
If class cxDbEmbeddedEntity is defined in xDbEmbeddedEntity.h, code have to be compiled successfully.
Facebook | Twitter | LinkedIn
Expert Elite Member
daniel_gearloose
ok,  i try it.. found some other mistakes and now I am steps further...
Thaaanks 🙂
