Create region in AutoCAD using pyautocad (Python)
tanmayms3009
tanmayms3009
According to the documentation for the "AddRegion" method provided on AutoCAD2022 Developer and ObjectARX Help: "https://help.autodesk.com/view/OARX/2022/ENU/?guid=GUID-74C8765E-EB4A-4773-ADD4-6C0F318FE6BE"
we need to pass the safearray of objects to Block or Modelspace to create a region.
Since I have been working on documenting the use of pyautocad as a means to automate AutoCAD tasks, I want to perform the same operation using python. But none of the python-based data structures (e.g. List, Tuples, Sets etc.) worked for adding a region. Also, I tried creating a customized array using "win32com" module, still no satisfactory output. Can anyone please guide me through this?
Thanks in advance.
Alexander.Rivilis
Try this code: https://adn-cis.org/forum/index.php?topic=7864.msg45040#msg45040
Facebook | Twitter | LinkedIn
Expert Elite Member
tanmayms3009
Many thanks for the response, Sir.
Can you please also tell me how to get a Region object in return? Because the AddRegion does not return a Region object but an Array of Variants.
Thanks in advance!
Alexander.Rivilis
Expert Elite Member
tanmayms3009
Yes correct. Thanks for your help once again.
