Create NET project
Create NET project
Create NET project
I can't create a .net mixed managed project in visual studio 2010, I am using win 7 64, I receive the message:
"Specified argument was out of the renge of valid values:
Parameter nane:value."
If anybody can help me i would be very grateful.
Thanks.
Alfred.NESWADBA
are you sure that this is a ARX-depending problem?
If I look >>>here<<< the problem has been asked a lot of times and seems to be a problem within your project.
Sorry, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thanks. But my problem arrising at the begining of the start up a project with the wizard.
please see the attachment.
Virupaksha_aithal
Autodesk Support
Autodesk Support
Can you try below step?
Please edit the following file like below
C:\Program Files (x86)\Autodesk\ObjectARX Wizards for AutoCAD 2012\ArxAppWiz\Scripts\1033\default.js
Line #122
Change
config.ManagedExtensions =bDotNetModule ;
into
config.ManagedExtensions =(bDotNetModule == 'True') ;
Regards
Virupaksha Aithal
Autodesk Developer Network
Virupaksha Aithal KM
Developer Technical Services
Thanks, with this i solve my problem.
