create hatch
create hatch
jignesh.rana
Message 1 of 14
create hatch
jignesh.rana
hi
i want to create hatch of any object but exclude inner object
for e.g if one rectangle has text inside then hatch will be exclude that text
Replies (13)
Message 2 of 14
tbrammer
You can use
Acad::ErrorStatus AcDbHatch::appendLoop(
    Adesk::Int32 loopType, // AcDbHatch::kDefault for a hole in the hatch, AcDbHatch::kExternal for external
    const AcDbObjectIdArray& dbObjIds // ids of the text entities
to create a hole around one or more DB resident (text-) entities. Or
    const AcGePoint2dArray& vertices,
    const AcGeDoubleArray& bulges
To create an arbitrary polyline shaped hole. When you are done call AcDbHatch::evaluateHatch() to update the hatch.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 14
jignesh.rana
sir could you please share code of objectarx ?
Message 4 of 14
jignesh.rana
here i attached drawing for refrence please look into this hatch is out of object
Message 5 of 14
tbrammer
Sample code:
void cmdHatch()
	ads_name           sset = { 0,0 };
	AcDbObjectIdArray outsideIds; // IDs of outer curve(s)/region
	AcDbObjectIdArray holeIds;    // IDs of inner text(s)/pline(s)/region that shall create ONE hole.
	acutPrintf(_T("\nSelect entities that form the outer conture: "));
	if (acedSSGet(NULL, NULL, NULL, NULL, sset) == RTNORM)
		outsideIds.setLogicalLength(0);
		Selset2ObjIdArray(sset, outsideIds);
		acedSSFree(sset);
	else
		return;
	Acad::ErrorStatus es;
	AcDbDatabase* db = acdbHostApplicationServices()->workingDatabase();
	AcDbHatch* hatch = new AcDbHatch();
	hatch->setDatabaseDefaults(db);
	es = hatch->appendLoop(AcDbHatch::kExternal, outsideIds);
	int stat = RTNORM;
	while (stat==RTNORM)
		acutPrintf(_T("\nSelect entities that form one inner hole: "));
		stat = acedSSGet(NULL, NULL, NULL, NULL, sset);
		if (stat == RTNORM)
			holeIds.setLogicalLength(0);
			Selset2ObjIdArray(sset, holeIds);
			acedSSFree(sset);
			es = hatch->appendLoop(AcDbHatch::kDefault, holeIds);
	hatch->evaluateHatch();
	postToDb(db, hatch);
long Selset2ObjIdArray(ads_name sset, AcDbObjectIdArray& objIdArr) {
	Adesk::Int32 selSetLen = 0, i;
	if (acedSSLength(sset, &selSetLen) != RTNORM)
		return -1;
	ads_name ename;
	AcDbObjectId objId;
	for (i = 0; i < selSetLen; i++)	{
		if (acedSSName(sset, i, ename) == RTNORM) {
			if (acdbGetObjectId(objId, ename) == Acad::eOk)
				objIdArr.append(objId);
	return selSetLen;
Message 6 of 14
jignesh.rana
sir please try in this drawing which i attached
Message 7 of 14
tbrammer
Works perfectly. Did I pick the right entities?
Message 8 of 14
jignesh.rana
Message 9 of 14
tbrammer
I don't know what you mean. Did you watch the video? Did I select the right entities?
Please post a DWG that only contains the entity that defines the outer bounds of the hatch and the text that shall be left out.
Which AutoCAD version do you use?
Message 10 of 14
tbrammer
It looks as if you created a external hatch loop using the bounding points of the MTEXT entity.
This is what SNOOPENTS from the ArxDbg.arx (<ARX>\samples\database\ARXDBG) shows for the MTEXT:
And this for the hatch:
If you use my code the inner loop will look like this:
Message 11 of 14
jignesh.rana
one more help required
want to set specific color for hatch for e.g red color i tried to set it
hatch->SetColorIndex(1);
but its not working
Message 12 of 14
tbrammer
Acad::ErrorStatus es = hatch->setColorIndex(1);
should work. Please check whether it returns es==Acad::eOk.
Did you open hatch for write and close it after changing the color?
Maybe the graphics need a refresh. Try _REGEN or save and reopen the drawing.
If the hatch isn't "solid" or "gradient" the color is applied to the pattern of the hatch. If no part of the pattern is visible, you will only see the background color of the hatch - or the background itself if the background color is "none". Try
AcCmColor color;
color.setColorIndex(1);
hatch->setBackgroundColor(color);
Message 13 of 14
jignesh.rana
in this logic if more than one closed polylines/regions in outer polyline then its not work
Message 14 of 14
jignesh.rana
please share objectarx code to exclude inner objects more than one including text.
please see attachment/image
