Common Language Runtime detected an invalid program.
I got error when I read file dwg using C#:
My code :
Database db = new Database(false, true)
db.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, false, null);
Error:
An unhandled exception of type 'System.InvalidProgramException' occurred in ReadCADFile.exe
Additional information: Common Language Runtime detected an invalid program.
How to resolve this problem ?
Alexander.Rivilis
@Anonymous
1. Wrong forum selected for this question. Right forum is https://forums.autodesk.com/t5/net/bd-p/152
2. You can not use AutoCAD .NET API with external exe-application. It can be used only in inproc dll addin, which loaded in AutoCAD with NETLOAD command.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Dear Alexander.Rivilis,
Thanks for your reply
You mean : I' LL build DLL then add them to AutoCad and use NetLoad Command to call them ?
Alexander.Rivilis
NETLOAD command is using not for call dll, but for load it into AutoCAD.
Expert Elite Member
Why then, in documentation for 2021, said that it can be used in .net standalone app?
https://help.autodesk.com/view/OARX/2021/ENU/?guid=GUID-71554E76-8FD5-4853-82CD-3587764CBCAC
Either documentation is wrong, or is incomplete - missing instructions how to do it.
Btw, I have similar problem, trying to read .cuix file (to customize UI) from standalone .net app.
artc2
Using the .NET API in a standalone program requires the RealDWG SDK which is a licensed product and not free.
