Change xref color with overrules
danipon71
danipon71
i need to color some entities using overrules.
Now I’m using AcGiDrawableOverrule::worldDraw.
It works fine with all entities but overrules.
Is there any way to color xref with AcGiDrawableOverrule?
My code (cleaned) + xref detection
    virtual Adesk::Boolean  worldDraw(AcGiDrawable* pSubject, AcGiWorldDraw * wd)
        bool xref = false;
        AcDbEntity *asEnt = AcDbEntity::cast(pSubject);
        if (asEnt) {
            if (asEnt->isKindOf(AcDbBlockReference::desc())) {
                AcDbBlockReference *pBR = AcDbBlockReference::cast(asEnt);
                AcDbObjectId idBlk = pBR->blockTableRecord();
                AcDbObject *pObj;
                acdbOpenObject(pObj, idBlk, AcDb::kForRead);
                AcDbBlockTableRecord * pBTR = AcDbBlockTableRecord::cast(pObj);
                if (pBTR != NULL) {
                    if (pBTR->isFromExternalReference()) {
                        xref = true;
                pObj->close();
            AcDbDatabase *db = asEnt->database();
            if (db) {
                TopDwgStatus* dwgstatus = TopDwgStatus::find(db);
                if (dwgstatus) {
                    AcDbObjectId idLay = asEnt->layerId();
                    wd->subEntityTraits().setColor(3);
        Adesk::Boolean retValue = inherited::worldDraw(pSubject, wd);
        return retValue;
Thanks in advance
deepak.a.s.nadig
Thank you for your patience.
Is there any way to color Xref with AcGiDrawableOverrule?
Attached is a simple project to add overrule to the AcDbEntity, where :
Adesk::Boolean testOverrule::worldDraw(AcGiDrawable* pSubject, AcGiWorldDraw* wd)
	if (asEnt) {
	return AcGiDrawableOverrule::worldDraw(pSubject, wd);
Having tested the project ( http://autode.sk/2p0je9E ), it works for changing the color of attached XRef .
Hope this helps.
danipon71
Thank you for the replay.
After doing some tests i've found out i was doing the "xref detection" part wrong.
I've changed my code like this and now it works:
        if (asEnt) {
            if(asEnt->database() != acdbCurDwg())
        Adesk::Boolean retValue = AcGiDrawableOverrule::worldDraw(pSubject, wd);
Thank you again
