C++ OARX Wizard for Visual Studio 2017
jordan
Message 1 of 9
jordan
Is there a way to get the C++ Wizard ( Project templates, .. ) working in VS2017?
Replies (8)
Message 2 of 9
Alexander.Rivilis
The same question I asked some months ago to DevHelp. Answer was No. So we have to wait until AutoCAD release will be built with VS 2017.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 9
I was wondering if you have the c++OARX of 2012,and do you know where to download the version?thankyou
Message 4 of 9
jordan
it's not supported anymore for download on the AutoDesk website, but I've found another link on the forum to download the older ObjectARX versions.
https://forums.autodesk.com/t5/programmirovanie-objectarx-arx/objectarx-sdk-starye-i-novye-versii/td...
Message 5 of 9
thankyou very much for the  reply,I found that my visual studio 2015needs the ARX2017or 2018 ,Luckily,I have found the download link in this http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627,but there is only a  ObjectARXWizards in installation package ,but where is the inc and lib(header file and library file)? and it confuses me.
Message 6 of 9
Alexander.Rivilis
You can download ObjectARX SDK from this page: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550
Expert Elite Member
Message 7 of 9
thankyou very much,I have solved the problem.
Message 8 of 9
Hi i am having the same problem as this gentlemen i just downloaded the latest release of ObjectARX SDK for ACAD 2018 and I also have the latest Visual Studio 2017 release. Only difference is i plan to use c#
The SDK archiver unzipped itself into a directory and promptly ended. There is a .ini file in the root directory pointing to a setup.exe which doesnt exist.
How do you finish the integration with Visual Studio?
Message 9 of 9
Nevermind, for anyone who see's this, in the System Requirements page Autodesk mentions that the 2017/2018 SDK's are only compatible with Visual Studio 2015 update 3.
