Autocad command to select entities
Message 1 of 9
what is command to select entities? That means clicking on a an entity calls a special autocad command, which is it?
I want to call it with acedCommand().
with kind regards,
Robert
Replies (8)
Message 2 of 9
Robert- írta:
> Hello,
> with kind regards,
> Robert
select
Message 3 of 9
"select" doesn´t show the grips. Is there another command?
Message 4 of 9
without commands:
void select()
ads_name l_selection_set;
acedSSAdd(NULL, NULL, l_selection_set;
for (......)
acedSSAdd(l_entity_name, l_selection_set, l_selection_set);
acedSSSetFirst(l_selection_set, l_selection_set);
acedSSFree(l_selection_set);
Message 5 of 9
acedSSSetFirst returns always -5001, that means Error.
What´s wrong? I give acedSSSetFirst only a selection set with one entity inside.
Message 6 of 9
> inside.
It works for me. Copy and paste the code fragment you use.
Message 7 of 9
I use this code to test it:
There is one entity on layer "0";
ads_name SelName;
struct resbuf *filter;
filter = acutBuildList(8, "0", RTNONE);
acedSSGet("X", NULL, NULL, filter, SelName);
long len;
acedSSLength(SelName, &len);
int a = acedSSSetFirst(SelName, SelName);
"len" is one, so creating the selection set should be done successful.
Thanks for your help.
Message 8 of 9
> ads_name SelName;
> long len;
addCommand - ACRX_CMD_USEPICKSET set?
As I sad that piece of code works in our app.
Message 9 of 9
Yes, it is set.
