AutoCAD 2013 plugin compatibility with AutoCAD 2019
EMD1954
Message 1 of 8
EMD1954
acedCommandS(RTSTR, _T("LAYER"), RTSTR, _T("T"), RTSTR, csLayer, RTSTR, NULL, RTNONE);
csLayer is a CString.  This line causes AutoCad 2019 to crash.
Any ideas?
Replies (7)
Message 2 of 8
EMD1954
Sorry - please disregard the "title".  It's just acedCommandS()
Message 3 of 8
Alexander.Rivilis
acedCommandS(RTSTR, _T("_LAYER"), RTSTR, _T("_Make"), RTSTR, LPCTSTR(csLayer), RTSTR, _T(""), RTNONE);
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 8
EMD1954
Alexander,
Thank you.  I have been doing it that way for more than 10 years and it worked in every previous version.  Without you telling me, how would I have ever found it.
Best,
Ed
Message 5 of 8
Alexander.Rivilis
@EMD1954 wrote:
Alexander,
Best,
Ed
Your code is completely incorrect:
1. NULL after RTSTR can produce Fatal Error
2. csLayer may have other pointer than LPCTSTR(csLayer)
3. Option _SET (e.g "T") can be used only if layer previously  created, but "_Make" create and set layer current.
Expert Elite Member
Message 6 of 8
EMD1954
Yes, now I understand.  But for the record, it worked that way in Autocad 2010, 2012, 2015 and 2017 without any problems.
Thank you - problem solved.
Ed
Message 7 of 8
autodaug
Fwiw, I see from an internal bug report that this crash was noticed in 2019 and is being looked at. Probably it was just an accident that the "incorrect" code (RTSTR followed by null) worked (or at least didn't crash) prior to 2019. And then some changes to AutoCAD's command handling implementation caused the code to suddenly start crashing in 2019, as an unintended side effect.
Message 8 of 8
EMD1954
Thank you.  I knew I wasn't crazy!
