ARX Wizard 2013 won't load into VC2010
EMD1954
Message 1 of 23
EMD1954
I downloaded the 2013 wizard and documentation, I ran the installation and it tells me it was successful.  Then I go to VC2010 and there exists a toolbar called "ObjectARX AddIn" but it has no buttons.  When I go to "Add or Remove Buttons -> Customize", the  "ObjectARX AddIn" Toolbar is there but the only think that shows up under "AddIn" is Visual Teefy.
I unloaded the wizard and reinstalled it but I'm having the same problem.
How did I lose the buttons and how do I get them back?
Ed
Replies (22)
Message 21 of 23
tbrammer
Cyrille, you wrote:
> ...as there is 3rd party tools which do a better work.
Which 3rd party tools you mean?
Where can I get them? Are they still available for ARX 2016 and 2017?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 22 of 23
EMD1954
Cyrille, You answered this one on May 17, 2012.  I am having the exact same problem (VS2015, ARXMFCWizard 2017), but I can't get it to work no matter which defaultxxxx.htm I use or how I rename them.  Dropdown for the Dialog ID doesn't exist.  Any advice would be appreciated.
Ed
Message 23 of 23
Alexander.Rivilis
@EMD1954
Look at this post: http://forums.autodesk.com/t5/objectarx/arx-wizard-2017-won-t-load-into-vc2015/m-p/6715960#M34684
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
