ARX MFC
ARX MFC
ARX MFC
I have a dialog w/ multiple text fields, etc.
I want to populate the values.. but they are not initializing:
CDlgFixture dlgFixt;
dlgFixt.m_strFixtType.SetWindowText(strCkt); // a CEdit control
dlgFixt.m_cmbFixtureBlock.SetWindowText(temp); //a CComboBox ctrl
dlgFixt.UpdateData(false) // fails - unsupported operation?
dlgFixt.DoModal(); // shows, but w/o my values initialized.
MS
Before declaring your instance of the dialog, add this line of code
CAcModuleResourceOverride resover;
The proper resources are not set, so the wrong dialog is being used, and
that control doesn't exist in that dialog hence the unsupported operation.
"Martin Schmid" wrote in message
news:F31F76A57E657BD58E145917AB9D7791@in.WebX.maYIadrTaRb...
> Thanks,
> MS
Besides that you have to override the resource handle, it might also be the
call to
UpdateData(FALSE) before DoModal(). Before DoModal the Dialog is not
created, so there are no controls accessible.
"Randy Sanders" schrieb im Newsbeitrag
news:C642EE78F8386A58B77A63E05333470D@in.WebX.maYIadrTaRb...
> > Thanks,
> > MS
It is the later... I need to do my initialization in OnInit, not prior to
calling DoModal.
"Andreas Mueller" wrote in message
news:2A630CF7F90FCB4B9CEF01AF9D6E0527@in.WebX.maYIadrTaRb...
the
> call to
operation.
> > > Thanks,
> > > MS
You can't set properties of controls before their windows have been
created. You'll need to either call CDialog::Create() manually (and handle
the dialog as a modeless dialog) before initializing controls, or do your
initializing in OnInitDialog(). The latter is simplest in most cases. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
