applying texture to dxf file
Hi, I want applying a texture to a dxf file which actually is triangulation network of terrain, I have no idea how to implement this. any suggestions will be appreciated.
tbrammer
Basically I would suggest to load the DXF into a new AcDbDatabase with AcDbDatabase::dxfIn().
Than iterate over the enties in the modelspace and use AcDbEntity::setMaterial() to assign an AcDbMaterial material with a texture to the entities you want. You can set the texture mapping with AcDbEntity::setMaterialMapper().
When you are done, save with AcDbDatabase::dxfOut().
Does this make sense to you?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
sorry for late reply, I got it. thanks.
