Hello Thomas,
thanks for your analysis of the problem at hand.
You are right, implementing custom entities and doing overrules is more on the unusual side.
Let me explain the base cause for our design decision: We have thousands and thousands of different 2d and 3d blocks that we want to display and enrich with features that only custom entities can provide with great satisfaction. The blocks are sufficient complex that it is not possible to make/draw the block geometry from the custom entity itself. Therefore, the block (BTR) is the supplier (or part) of the geometry that the custom entity needs to draw.
When creating/inserting a custom entity into the drawing, the appropriate block is added as an AcDbBlockTableRecord (BTR) to the block table. The custom entity saves the ObjectId (oIdBtr) of the BTR and draws the BTR with
AcDbBlockTableRecordPointer pBTR = nullptr;
pBTR.open(oIdBtr, AcDb::kForRead)
giDraw->rawGeometry()->draw(pBTR);
That is almost very straightforward.
The problem is that the blocks itself contain multitudes of own layers, that are anonymous and therefore hidden from the user. With the layers, we control different design and visibility aspects of the displayed blocks and the overall application. Also, some native trait of the geometry "inside" the block (like color, or in some cases the layer) needs to change according to special user needs and/or application requirements.
Here the fun starts, because this is NOT possible when just implementing
The workaround has been to create clones of all entities of a given block, like
AcDbSmartObjectPointer<AcDbHatch> pHatch(<ObjectId_of_entity_in_block>, AcDb::kForRead);
AcDbHatch *pHatchClone = AcDbHatch::cast(pHatch->clone());
giDraw->rawGeometry()->draw(pHatchClone);
With this, we are able to control the entity traits before we draw the entity. The downside is that each object in the drawing that uses the block-and-clone-mechanism creates its own clone and uses some resources while doing so. With 2d geometry that is largely ok, but trying to do this with some (large) AcDbSolid3d geometry, the performance penalty is simply too great and quickly not feasible.
So with 2d geometry, we stuck with the block-and-clone-mechanism.
With the 3d geometry, we stayed with ->draw(pBTR). But there is still the catch with the block layers and traits.
So we tried to be clever and opend the BTR before drawing the BTR and changed the entity traits (of the entities inside the block) to desired values. After draw, we opend the BTR again and reset the values to the original state.
This works ok in most circumstances, but fails spectacularly when trying to render the 3d block displaying custom entity: Some of the entities are just not rendered!
To quote the ADN (Autodesk Developer Network) on this:
This workflow upgrades the entities of the BTR and modifies them. When the object is closed, it sends an onModified() event to all 3D graphic systems (GSN is the one that renders) and this event triggers an invalidation of the graphics for that node.
The question is: How to archieve our design goals AND be able to render the 3d custom entity block geometry?
With some great help from the ADN (thanks, folks!), who largely contributed with sample code for the AcGiDrawableOverrule, we have been able to solve this and get sufficient performance gains while drawing the BTR's.
Also, the overhead of the additional introduced code is removed for good.
@tbrammer: Using the Adesk::UInt32 subSetAttributes(AcGiDrawableTraits*) would not have been solved the problem. We tried it, and the ADN also says that in this setup it would not work satisfactory.
BUT the downside of the AcGiDrawableOverrule is, that the layer overrule for plotting (see above) as well as the overrule for the 3D GS (see here) is not working. So there is still some significant downside to applying the overrule.
Concluding this post, you find our customized overrule here:
/* this draws the btr */
void AuStEntity::asDrawBtr(
AcGiCommonDraw *giDraw,
AcDbObjectId &oIdBtr,
AcDbObjectId &oIdLayer,
Adesk::UInt16 &iEntityColor,
AcDb::LineWeight *lwObject,
AcCmTransparency &transp,
AcGeMatrix3d &transMat,
AcGiWorldDraw *pWd /* = nullptr */
/* do nothing */
if (oIdBtr == AcDbHardPointerId::kNull)
return;
/* open btr for read */
if (Acad::eOk != pBTR.open(oIdBtr, AcDb::kForRead))
oIdBtr = AcDbHardPointerId::kNull;
return;
/* call THIS to overrule properties after draw() */
asBtrEntityOverrule(
giDraw,
lwObject,
transp,
iEntityColor
/* geometry draw */
if (giDraw != nullptr)
giDraw->rawGeometry()->pushModelTransform(transMat);
giDraw->rawGeometry()->popModelTransform();
else if (pWd != nullptr)
pWd->rawGeometry()->pushModelTransform(transMat);
pWd->rawGeometry()->draw(pBTR);
pWd->rawGeometry()->popModelTransform();
/* make sure the entity overrule is deactivated */
asBtrEntityOverruleOff();
/* return */
return;
} // END
// ** AuStSubEntityTraits **
class AuStSubEntityTraits : public AcGiSubEntityTraits
public:
AuStSubEntityTraits(AcGiSubEntityTraits* pTraits) : m_pTraits(pTraits) {}
/* no - ops so that entity can't change traits */
void setColor(const Adesk::UInt16 color) override {}
void setTrueColor(const AcCmEntityColor& color) override {}
void setTransparency(const AcCmTransparency& transparency) override {};
void setLineWeight(const AcDb::LineWeight lw) override {};
#ifdef ACAD2021_AND_HIGHER
void setLineWeight(const AcDb::LineWeight lw, const char lweight_index) override {};
#endif
/* forwarders */
void setLayer(const AcDbObjectId layerId) override { m_pTraits->setLayer(layerId); }
void setLineType(const AcDbObjectId linetypeId) override { m_pTraits->setLineType(linetypeId); }
void setSelectionMarker(const Adesk::LongPtr markerId) override { m_pTraits->setSelectionMarker(markerId); }
void setFillType(const AcGiFillType type) override { m_pTraits->setFillType(type); }
void setLineTypeScale(double dScale = 1.0) override { m_pTraits->setLineTypeScale(dScale); }
void setThickness(double dThickness) override { m_pTraits->setThickness(dThickness); }
void setVisualStyle(const AcDbObjectId visualStyleId) override { m_pTraits->setVisualStyle(visualStyleId); }
void setPlotStyleName(
AcDb::PlotStyleNameType type,
const AcDbObjectId& id = AcDbObjectId::kNull) override
m_pTraits->setPlotStyleName(type, id);
void setMaterial(const AcDbObjectId materialId) override { m_pTraits->setMaterial(materialId); }
void setMapper(const AcGiMapper* mapper) override { m_pTraits->setMapper(mapper); }
void setSectionable(bool bSectionable) override { m_pTraits->setSectionable(bSectionable); }
Acad::ErrorStatus setDrawFlags(Adesk::UInt32 flags) override { return m_pTraits->setDrawFlags(flags); }
Acad::ErrorStatus setShadowFlags(ShadowFlags flags) override { return m_pTraits->setShadowFlags(flags); }
void setSelectionGeom(bool bSelectionflag) override { m_pTraits->setSelectionGeom(bSelectionflag); }
void setFill(const AcGiFill* pFill) override { m_pTraits->setFill(pFill); }
Adesk::UInt16 color(void) const override { return m_pTraits->color(); }
AcCmEntityColor trueColor(void) const override { return m_pTraits->trueColor(); }
AcDbObjectId layerId(void) const override { return m_pTraits->layerId(); }
AcDbObjectId lineTypeId(void) const override { return m_pTraits->lineTypeId(); }
AcGiFillType fillType(void) const override { return m_pTraits->fillType(); }
AcDb::LineWeight lineWeight(void) const override { return m_pTraits->lineWeight(); }
double lineTypeScale(void) const override { return m_pTraits->lineTypeScale(); }
double thickness(void) const override { return m_pTraits->thickness(); }
AcDbObjectId visualStyle(void) const override { return m_pTraits->visualStyle(); }
AcDb::PlotStyleNameType getPlotStyleNameId(AcDbObjectId& idResult) const override { return m_pTraits->getPlotStyleNameId(idResult); }
AcDbObjectId materialId(void) const override { return m_pTraits->materialId(); }
const AcGiMapper* mapper(void) const override { return m_pTraits->mapper(); }
bool sectionable(void) const override { return m_pTraits->sectionable(); }
Adesk::UInt32 drawFlags(void) const override { return m_pTraits->drawFlags(); }
ShadowFlags shadowFlags(void) const override { return m_pTraits->shadowFlags(); }
bool selectionGeom(void) const override { return m_pTraits->selectionGeom(); }
AcCmTransparency transparency(void) const override { return m_pTraits->transparency(); }
const AcGiFill* fill(void) const override { return m_pTraits->fill(); }
void pushMarkerOverride(
bool flag,
m_pTraits->pushMarkerOverride(flag, markerId);
void popMarkerOverride(void) override { m_pTraits->popMarkerOverride(); }
void clearMarkerOverride(void) override { m_pTraits->clearMarkerOverride(); }
private:
AcGiSubEntityTraits* m_pTraits;
// ** AuStWorldDraw **
class AuStWorldDraw : public AcGiWorldDraw
public:
AuStWorldDraw(AcGiWorldDraw* pWD) : m_pWD(pWD), m_traits(&pWD->subEntityTraits()) { }
AcGiWorldGeometry& geometry() const override { return m_pWD->geometry(); }
AcGiRegenType regenType() const override { return m_pWD->regenType(); }
Adesk::Boolean regenAbort() const override { return m_pWD->regenAbort(); }
AcGiGeometry* rawGeometry() const override { return m_pWD->rawGeometry(); }
Adesk::Boolean isDragging() const override { return m_pWD->isDragging(); }
Adesk::UInt32 numberOfIsolines() const override { return m_pWD->numberOfIsolines(); }
AcGiContext* context() override { return m_pWD->context(); }
double deviation(const AcGiDeviationType dev, const AcGePoint3d& pt) const override
return m_pWD->deviation(dev, pt);
AcGiSubEntityTraits& subEntityTraits() const override
/* hook sub entity traits */
return const_cast<AuStWorldDraw*>(this)->m_traits;
private:
AcGiWorldDraw* m_pWD;
AuStSubEntityTraits m_traits;
// ** AuStViewportDraw **
class AuStViewportDraw : public AcGiViewportDraw
public:
AuStViewportDraw(AcGiViewportDraw* pVD) : m_pVD(pVD), m_traits(&m_pVD->subEntityTraits()) { }
AcGiViewportGeometry& geometry() const override { return m_pVD->geometry(); }
AcGiRegenType regenType() const override { return m_pVD->regenType(); }
Adesk::Boolean regenAbort() const override { return m_pVD->regenAbort(); }
AcGiGeometry* rawGeometry() const override { return m_pVD->rawGeometry(); }
Adesk::Boolean isDragging() const override { return m_pVD->isDragging(); }
Adesk::UInt32 numberOfIsolines() const override { return m_pVD->numberOfIsolines(); }
AcGiContext* context() override { return m_pVD->context(); }
return m_pVD->deviation(dev, pt);
return const_cast<AuStViewportDraw*>(this)->m_traits;
private:
AcGiViewportDraw* m_pVD;
// Class Macros
// ** AuStEntityOverrule **
/* See SDK Documentation under "Class Implementation Macros" */
/* Or rxBoiler.h */
// ACRX_DEFINE_MEMBERS(AuStEntityOverrule); /* LINKER >> rxInit() not solved */
// ACRX_CONS_DEFINE_MEMBERS(AuStEntityOverrule, AcGiDrawableOverrule, 1); /* compile error >> build abstract class not possible */
ACRX_NO_CONS_DEFINE_MEMBERS(AuStEntityOverrule, AcGiDrawableOverrule); /* build ok */
// Static Member
AuStEntityOverrule *AuStEntityOverrule::_pEntityOverrule = nullptr;
// Constructor, Destructor
AuStEntityOverrule::AuStEntityOverrule()
if (AuStEntityOverrule::desc() == nullptr)
AuStEntityOverrule::rxInit();
acrxBuildClassHierarchy();
AuStEntityOverrule::~AuStEntityOverrule()
// PUBLIC Class Methods
void AuStEntityOverrule::Activate()
/* is already instantiated */
if (_pEntityOverrule != nullptr)
return;
/* new overrule */
_pEntityOverrule = new AuStEntityOverrule();
/* add overrule */
AcRxOverrule::addOverrule(
AcDbEntity::desc(),
_pEntityOverrule,
true
/* enable overrule */
_pEntityOverrule->Enable();
} // END
void AuStEntityOverrule::Deactivate(bool bUnregister /* = true */)
if (_pEntityOverrule == nullptr)
return;
/* Deactivate from AcRx::AppRetCode On_kUnloadAppMsg() */
/* disable overrule */
_pEntityOverrule->Disable();
if (bUnregister)
AcRxOverrule::removeOverrule(
AcDbEntity::desc(),
_pEntityOverrule
delete _pEntityOverrule;
} // END
void AuStEntityOverrule::Enable()
m_bEnableOverrule = true;
if (!AcRxOverrule::isOverruling())
AcRxOverrule::setIsOverruling(true);
void AuStEntityOverrule::Disable()
m_bEnableOverrule = false;
/* these have no effect! the flag will be true even when setting it to false... */
/* This maybe come from the overrule not removed from AcRxOverrule::removeOverrule() */
if (AcRxOverrule::isOverruling())
AcRxOverrule::setIsOverruling(false);
void AuStEntityOverrule::updateTraits(
AcDb::LineWeight lwObject,
AcDbObjectId& layerOid,
m_lwObject = lwObject;
m_transp = transp;
m_layerOid = layerOid;
m_iEntityColor = iEntityColor;
/* enable overrule >> need to disable overrule after BTR draw */
Enable();
} // END
// PRIVATE Class Methods
bool AuStEntityOverrule::isApplicable(const AcRxObject *pOverruledSubject) const
/* here we need to implement our own ON/OFF flag to enable or disable the per object overrule */
/* the IsOverruling() from the base class will be always 1, even if setIsOverruling(false) is applied */
if (m_bEnableOverrule)
return true;
else
return false;
} // END
Adesk::Boolean AuStEntityOverrule::worldDraw(AcGiDrawable* pSubject, AcGiWorldDraw* wd)
/* skip entities for overrule */
AcRxClass* rxClass = skipEntity(pSubject);
if (rxClass != AcDbEntity::desc())
/* returning false for AcDbMText is neccessary for text and text background color */
if (rxClass == AcDbMText::desc())
return Adesk::kFalse;
/* return base class world draw */
else
return AcGiDrawableOverrule::worldDraw(pSubject, &AuStWorldDraw(wd));
/* The default attributes are set, go ahead and override */
setTraits(
pSubject,
wd,
nullptr
/* return */
} // END
void AuStEntityOverrule::viewportDraw(AcGiDrawable* pSubject, AcGiViewportDraw* vd)
if (AcDbEntity::desc() != skipEntity(pSubject))
return AcGiDrawableOverrule::viewportDraw(pSubject, vd);
setTraits(
pSubject,
nullptr,
vd
/* return */
} // END
void AuStEntityOverrule::setTraits(
AcGiDrawable *pSubject,
AcGiWorldDraw *wd,
AcGiViewportDraw *vd
/* get entity */
AcDbEntity *pEnt = AcDbEntity::cast(pSubject);
/* When the entity is part of a BTR, we check eByLayer and eByBlock */
/* If the color of the entity is fixed (others than eByLayer || eByBlock), we DO NOT change the color! */
/* get layer color */
if (pEnt->colorIndex() == AuSt::eByLayer)
/* get layer color from layer */
m_iEntityColor = getLayerColor(pEnt->layerId());
/* set color */
if ((pEnt->colorIndex() == AuSt::eByBlock) ||
(pEnt->colorIndex() == AuSt::eByLayer))
if (wd != nullptr)
wd->subEntityTraits().setColor(m_iEntityColor);
else if (vd != nullptr)
vd->subEntityTraits().setColor(m_iEntityColor);
/* set lineweight */
if (wd != nullptr)
wd->subEntityTraits().setLineWeight(m_lwObject);
vd->subEntityTraits().setLineWeight(m_lwObject);
/* set transparency */
if (wd != nullptr)
wd->subEntityTraits().setTransparency(m_transp);
vd->subEntityTraits().setTransparency(m_transp);
/* get layer from BTR entity when input is NULL >> is used for viewport display */
if (m_layerOid == AcDbObjectId::kNull)
m_layerOid = pEnt->layerId();
/* otherwise, we use the BTR entity layer when layerOid is null */
/* set layer */
if (wd != nullptr)
wd->subEntityTraits().setLayer(m_layerOid);
vd->subEntityTraits().setLayer(m_layerOid);
/* Housekeeping */
pEnt = nullptr;
/* return */
return;
} // END
Adesk::UInt16 AuStEntityOverrule::getLayerColor(AcDbObjectId &oId)
Adesk::UInt16 retValue = AuSt::eBlackWhite;
AcDbLayerTableRecord* pLTR = nullptr;
if (Acad::eOk == acdbOpenObject(
pLTR,
oId,
AcDb::kForRead))
retValue = pLTR->color().colorIndex();
pLTR->close();
pLTR = nullptr;
return retValue;
} // END
AcRxClass* AuStEntityOverrule::skipEntity(AcGiDrawable* pSubject)
/* skip AcDbAttributeDefinition */
AcDbAttributeDefinition* pAtt = AcDbAttributeDefinition::cast(pSubject);
if (pAtt != nullptr)
pAtt = nullptr;
return AcDbAttributeDefinition::desc();
/* skip AcDbMText */
AcDbMText* pMtxt = AcDbMText::cast(pSubject);
if (pMtxt != nullptr)
pMtxt = nullptr;
return AcDbMText::desc();
/* return */
return AcDbEntity::desc();
} // END
