AcEditorReactor doesn't work if ACRX_CONS_DEFINE_MEMBE used
Hi All,
I am writing sample codes in AutoCAD 2008 debug environment without using ObjectARX Wizard. I am just creating a dll with .arx extension.
A reactor class named AsdkEdEmployeeReactor is created as a common c++ class. It inherits AcEditorReactor. The constructor is:
if ( autoInitAndRelease ) {
if ( acedEditor )
acedEditor->addReactor (this) ;
else
mbAutoInitAndRelease =false ;
2 virtual methods - commandWillStart and commandEnded implemented.
In acrxEntryPoint(...) method, a reactor object is created and added:
pEdEmployeeReactor = new AsdkEdEmployeeReactor(true);
Everything works fine in these simple ways. And the commandWillStart and commandEnded can be called when the user run commands. But if the ACRX_DECLARE_MEMBERS(AsdkEdEmployeeReactor) and ACRX_CONS_DEFINE_MEMBERS(AsdkEdEmployeeReactor, AcEditorReactor, 0) are added the the class, the 2 virtual methods will not be invoked when commands are run. And this is the way the ObjectARX Wizard does when creating reactor class - the 2 macros will be added.
This situation only happens on AcEditorReactor subclasses as I found. Those classes inheriting from AcDbDatabaseReactor and AcDbObjectReactor works well in spite of whether macros are added or not.
Any information about that?
Thanks.
Jerry
Jerry:
Just a hunch, but make sure you 'Rebuild All' after making the change. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Yes. I "Clean" and "Rebuild All" and am sure I "Appload" the right .arx file. But the virtual methods still don't work if the macros are added.
What do these macors do to the reactor?
Does your code call acrxBuildClassHierarchy() ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:[email protected]...
Thanks, Tony. You are right. After I added the following code to the kInitAppMsg case in acrxEntryPoint(...) method, things go right:
AsdkEdEmployeeReactor::rxInit();
acrxBuildClassHierarchy();
I checked the AcRxDbxApp::On_kInitAppMsg(...) virtual method which is called by wizzard generated code in dbxEntryPoint.h file. Both the rxInit() and acrxBuildClassHierarchy() are called.
Thanks again for all your quick replies.
