acedCmd for ObjectARX 2015 and 2016
abdulhaseeb114
abdulhaseeb114
my below coding for ObjectARX 2014 is working well,
const resbuf *cmdlist;
cmdlist = acutBuildList(RTSTR, _T("_QSAVE"), 0);
acedCmd(cmdlist);
but I need the same to be work with my ObjectARX 2015 and 2016.
Please help me.
Alexander.Rivilis
What about this code:
#include "acedCmdNF.h"
acedCommandS(RTSTR, _T("_QSAVE"), 0);
Facebook | Twitter | LinkedIn
Expert Elite Member
abdulhaseeb114
Thanks For your help this Working good.....
tbrammer
Just some notes:
  1. You can replace acedCmd(cmdlist) by acedCmdS(cmdlist) as well.
  2. You should read the section "acedCommand Migration" in <ObjectARX 2015>\docs\readarx.chm.
    Using acedCmdS() and acedCommandS() is fine if your command is passed completely to the call - like in your case. Otherwise you have to use acedCommandC() / acedCmdC() which is quite hard to understand and implement. Better get rid of those acedCommand() calls!
  3. Be aware that your code won't compile under ARX 2014 and earlier if you simply change to the "S-versions". To solve this problem you can put the following #define statements into stdafx.h:
#if ACADVER < 20
    //ARX 2014 and earlier (ACADVER is a preprocessor definition that I set in each project configuration)
    #define acedCommandS acedCommand
    #define acedCmdS acedCmd
#endif
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
swaywood
Your answer is helpful, thanks so much.
