AcDbDatabase::dxfout
Here is the situatlion:
The default file format in the AutoCAD Options Dialog is set to AutoCAD 2010 DXF.
If I open a DXf file, make a modification to it and save it using the QSave command, AutoCAD will make a backup copy of the dxf file and save the new version.
If I do the same thing but use my own ARX command to save the file using the AcDbDatabase::dxfOut function, the function returns an "eFileAccessErr" status code and AutoCAD fails to create the backup file or save the DXF file.
If I set the default format to a drawing format, load a drawing and use the AcDbDatabase::saveAs function in my command to save the file, AutoCAD will make a backup copy and save the DWG file.
Is it possible to use the AcDbDatabase::dxfOut function to make a backup copy of the loaded DXF file and save a new copy like the saveAs function does for drawing files?
If so, what do I need to do to my code to make it work.
fenton_webb
have you tried using acdbDxfOutAs2000, acdbDxfOutAs2004, etc etc
Fenton Webb
AutoCAD Engineering
Yes. I have already tried those functions with the same results. If the file is already there and opened in AutoCAD, the functions will not make a backup copy of the DXF file and replace it with the new version.
Richard L. Baker II
Svc Info Developer III
ES Apps Development US
[email protected]
T +1 512 319 3637
HP Enterprise Services
[cid:[email protected]]
Please print thoughtfully
fenton_webb
Can you post the code you are using to call AcDbDatabase::dxfOut() please?
Another option is to use the COM API, e.g. AcadApplication::AcadDocument.ActiveDocument.SaveAs()
Fenton Webb
AutoCAD Engineering
Here is the code I am trying to use. The DWG formats work just fine. AutoCAD will make a backup copy and save the new file. It doesn't work for the DXF formats.
Acad::ErrorStatus es;
CString csDwgFullName = GetDwgFilename();
grDocData.bSaveDwg = true;
AcApDocument *pDoc = acDocManager->curDocument();
AcDbDatabase *pDb = pDoc->database();
AcApDocument::SaveFormat saveFormat = pDoc->formatForSave();
bool bDwgFormat(true);
AcDb::AcDbDwgVersion dwgVersion = AcDb::kDHL_CURRENT;
switch (saveFormat)
case AcApDocument::k2010_dxf:
bDwgFormat = false;
break;
case AcApDocument::k2007_dxf:
bDwgFormat = false;
case AcApDocument::k2007_dwg:
dwgVersion = AcDb::kDHL_1021;
break;
case AcApDocument::k2004_dxf:
bDwgFormat = false;
case AcApDocument::k2004_dwg:
dwgVersion = AcDb::kDHL_1800;
break;
case AcApDocument::k2000_dxf:
bDwgFormat = false;
case AcApDocument::k2000_dwg:
dwgVersion = AcDb::kDHL_1015;
break;
case AcApDocument::kR14_dwg:
dwgVersion = AcDb::kDHL_1014;
break;
case AcApDocument::kR12_dxf:
bDwgFormat = false;
dwgVersion = AcDb::kDHL_1009;
break;
if (bDwgFormat)
es = pDb->saveAs(csDwgFullName, true, dwgVersion);
else
csDwgFullName.Replace(_T(".dwg"), _T(".dxf"));
csDwgFullName.Replace(_T(".DWG"), _T(".DXF"));
es = pDb->dxfOut(csDwgFullName, 16, dwgVersion);
Richard L. Baker II
[email protected]
T +1 512 319 3637
Balaji_Ram
Hi Richard,
I wanted to try out the COM API as my colleague Fenton Webb had already suggested and it worked.
As the "SaveAs" method in COM API cannot save dxf files, I used the "SendCommand".
I tried it this way :
1. Start AutoCAD 2014
2. Open a 2013 DXF file
3. Make some changes
4. Run the command to save the dxf file to the same path
It saved the dxf to the original file and created a .bak for it.
Here is the sample code :
#include <acadi.h>
#pragma warning( disable : 4278 )
// Makes change to the tlb name based on the AutoCAD version.
// For ex : acax18enu.tlb for AutoCAD 2010/2011 and 2012
//          acad19enu.tlb for AutoCAD 2013
#import "acax19ENU.tlb" no_implementation raw_interfaces_only named_guids
#pragma warning( default : 4278 )
static void AdskMyTestTTG(void)
	AcApDocument *pDoc = acDocManager->mdiActiveDocument();
	const TCHAR* dwgFileName;
    pDb->getFilename(dwgFileName);
	AcApDocument::SaveFormat sf = pDoc->formatForSave();
	CString csDxfFullName(dwgFileName);
	csDxfFullName.Replace(_T(".dwg"), _T(".dxf"));
	csDxfFullName.Replace(_T(".DWG"), _T(".DXF"));
	CWinApp *pApp = acedGetAcadWinApp();
	HRESULT hRes;
	LPDISPATCH pDisp=NULL;
	if (!pApp)
		return;
	pDisp=pApp->GetIDispatch(TRUE);
	if (!pDisp)
		return;
	CComPtr<AutoCAD::IAcadApplication> pComApp;
	hRes=pDisp->QueryInterface(IID_IAcadApplication, (void**)&pComApp);
	if (FAILED(hRes))
		return;
	CComPtr<AutoCAD::IAcadDocument> pComDoc;
	hRes=pComApp->get_ActiveDocument(&pComDoc);
	if (FAILED(hRes))
		return;
	VARIANT_BOOL isSaved;
	HRESULT hr = pComDoc->get_Saved(&isSaved);
	if(isSaved == 0)
		CString strCommand("FILEDIA\n0\n");
		BSTR bstCommand = strCommand.AllocSysString();
		hRes = pComDoc->SendCommand(bstCommand);
		::SysFreeString(bstCommand);
		// saveas
		// dxf
		// 16
		// path
		// replace ? : yes
		strCommand.Format(ACRX_T("saveas\nDXF\n16\n%s\ny\n"), csDxfFullName);
		if (SUCCEEDED(hRes))
			acutPrintf( _T("Saved."));
	else
		acutPrintf( _T("No changes to save."));
Balaji
Developer Technical Services
Autodesk Developer Network
Balaji_Ram
Sorry, An update to my earlier reply.
The "SaveAs" method in COM API does save dxf files, but I did not find it creating a .bak file.
Balaji
