AcDbArcDimension as dynamic dimension
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello.
I have created Jig with an arc length dynamic dimension.
But I'm unable to set the desired arc length through the edit field of the dimension.
Any entered value is interpreted as an error (frame of the edit field turns red).
At the same time, any linear dynamic dimension based on AcDbAlignedDimension or AcDbRotatedDimension works wonderful.
Can I use the class AcDbArcDimension as dynamic dimension?
I have created sample project for test, which creates an arc by center, start and end points.
The implementation of the dimData() in test class looks folows:
There is one small problem: If we remove the comments on the call pArcDim->setDynamicDimension(true), the field for editing dimension value always change its location on (0,0,0).
Full text of the source code :
ArcTestJig.h
#pragma once class CArcTestJig: public AcEdJig { public: CArcTestJig(); virtual ~CArcTestJig(); //- dynamic dimension data setup virtual AcDbDimDataPtrArray* dimData (const double dimScale) override; //- dynamic dimension data update virtual Acad::ErrorStatus setDimValue(const AcDbDimData* dimData, const double dimValue) override; virtual Adesk::Boolean update() override; virtual DragStatus sampler() override; virtual AcDbEntity* entity() const override { return m_pArc; } AcEdJig::DragStatus start(); protected: void releaseDimData(); void updateDimData(); void setEndAngleTo(AcGePoint3d pntEnd); protected: #define ARCDIM_OFFSET 20.0 enum stage { center = 1, startpnt, endpnt }; stage m_Stage; AcGePoint3d m_PntPrev; AcDbArc* m_pArc; AcDbDimDataPtrArray* m_pDimData; double __PI; }; void CreateArc();
ArcTestJig.cpp
#include "StdAfx.h" #include "ArcTestJig.h" ////////////////////////////////////////////// CArcTestJig::CArcTestJig(): m_Stage(center), m_pDimData(NULL), __PI(atan (1.)*4) { m_pArc = new AcDbArc(AcGePoint3d::kOrigin, AcGeVector3d::kZAxis, 100., 0., __PI/2); } CArcTestJig::~CArcTestJig() { releaseDimData(); }; void CArcTestJig::releaseDimData() { if(m_pDimData == NULL) return; for(int ii = 0; ii < m_pDimData->length(); ii++) delete m_pDimData->at(ii); delete m_pDimData; m_pDimData = NULL; } void CArcTestJig::updateDimData() { if(m_pDimData == NULL || m_pArc == NULL) return; if(m_pDimData->length() < 2) return; double dRadius = m_pArc->radius(); AcGePoint3d pntCenter = m_pArc->center(); AcGePoint3d pntStart; m_pArc->getStartPoint(pntStart); double dStart; m_pArc->getStartParam(dStart); AcGePoint3d pntEnd; m_pArc->getEndPoint(pntEnd); double dEnd; m_pArc->getEndParam(dEnd); AcDbArcDimension* pArcDim = AcDbArcDimension::cast(m_pDimData->at(0)->dimension()); if(pArcDim) { pArcDim->setArcSymbolType(2); // no symbol pArcDim->setCenterPoint(pntCenter); pArcDim->setXLine1Point(pntStart); pArcDim->setXLine2Point(pntEnd); pArcDim->setArcStartParam(dStart); pArcDim->setArcEndParam(dEnd); AcGeVector3d vStart = (pntStart - pntCenter).normalize(); AcGeVector3d vEnd = (pntEnd - pntCenter).normalize(); AcGeVector3d vMid = vStart + vEnd; vMid.normalize(); if(vStart.angleTo(vEnd, m_pArc->normal()) > __PI) vMid.negate(); pArcDim->setArcPoint(pntCenter + (dRadius + ARCDIM_OFFSET)*vMid ); pArcDim->setHasLeader(false); } AcDbAlignedDimension* pChordDim = AcDbAlignedDimension::cast(m_pDimData->at(1)->dimension()); if(pChordDim) { pChordDim->setXLine1Point(pntStart); pChordDim->setXLine2Point(pntEnd); AcGeVector3d vDir = (pntEnd - pntStart).normalize(); pChordDim->setDimLinePoint(pntStart + ARCDIM_OFFSET*vDir.perpVector()); } } AcDbDimDataPtrArray* CArcTestJig::dimData (const double dimScale) { if(m_Stage != endpnt) return NULL; releaseDimData(); m_pDimData = new AcDbDimDataPtrArray(); AcDbDimData* pNewData(NULL); // Arc Dimension AcDbArcDimension* pArcDim = new AcDbArcDimension(); pArcDim->setDatabaseDefaults(); pArcDim->setNormal(m_pArc->normal()); pArcDim->setElevation(0.0); pArcDim->setHorizontalRotation(0.0); pArcDim->setDimscale(dimScale); pArcDim->setDimtad(1); // pArcDim->setDynamicDimension(true); pNewData = new AcDbDimData(pArcDim); pNewData->setDimHideIfValueIsZero(false); pNewData->setDimEditable(true); pNewData->setDimFocal(true); m_pDimData->append(pNewData); // Chord Dimension AcDbAlignedDimension* pChordDim = new AcDbAlignedDimension(); pChordDim->setDatabaseDefaults(); pChordDim->setNormal(m_pArc->normal()); pChordDim->setElevation(0.0); pChordDim->setHorizontalRotation(0.0); pChordDim->setDimtad(1); pChordDim->setDynamicDimension(true); pNewData = new AcDbDimData(pChordDim); pNewData->setDimHideIfValueIsZero(false); pNewData->setDimEditable(true); pNewData->setDimFocal(false); m_pDimData->append(pNewData); // set dimension location updateDimData(); return m_pDimData; } Acad::ErrorStatus CArcTestJig::setDimValue(const AcDbDimData* dimData, const double dimValue) { AcDbDimension* pDim = dimData->dimension(); AcDbArcDimension* pArcDim = AcDbArcDimension::cast(pDim); if(pArcDim) { AcGePoint3d pntNewEnd; Acad::ErrorStatus es = m_pArc->getPointAtDist(dimValue, pntNewEnd); if(Acad::eOk != es) return es; setEndAngleTo(pntNewEnd); return Acad::eOk; } else { AcDbAlignedDimension* pChordDim = AcDbAlignedDimension::cast(pDim); if(pChordDim) { double dRadius = m_pArc->radius(); if(dimValue > dRadius*2) return Acad::eNotApplicable; double dAngDlt = asin(dimValue/(dRadius*2)); double dNewEnd = m_pArc->startAngle() + dAngDlt*2; m_pArc->setEndAngle(dNewEnd); return Acad::eOk; } } return Acad::eInvalidInput; } void CArcTestJig::setEndAngleTo(AcGePoint3d pntEnd) { AcGeVector3d vEnd = (pntEnd - m_pArc->center()).normalize(); double dNewEnd = vEnd.angleTo(AcGeVector3d::kXAxis, m_pArc->normal().negate()); // if(dNewEnd > __PI) // dNewEnd -= __PI*2; m_pArc->setEndAngle(dNewEnd); } Adesk::Boolean CArcTestJig::update() { if(m_pArc == NULL) return false; switch(m_Stage) { case center: m_pArc->setCenter(m_PntPrev); break; case startpnt: { AcGeVector3d vStart = m_PntPrev - m_pArc->center(); double dRadius = vStart.length(); vStart.normalize(); double dStart = vStart.angleTo(AcGeVector3d::kXAxis, m_pArc->normal().negate()); if(dStart > __PI) dStart -= __PI*2; m_pArc->setRadius(dRadius); m_pArc->setStartAngle(dStart); m_pArc->setEndAngle(dStart + __PI/2); } break; case endpnt: setEndAngleTo(m_PntPrev); break; default: return false; } updateDimData(); return true; } AcEdJig::DragStatus CArcTestJig::sampler() { setUserInputControls((UserInputControls) ( AcEdJig::kAccept3dCoordinates | AcEdJig::kNullResponseAccepted)); DragStatus sts; AcGePoint3d pntTemp; if(m_Stage == startpnt) sts = acquirePoint(pntTemp, m_pArc->center()); else sts = acquirePoint(pntTemp); if(sts == AcEdJig::kNormal) { if(pntTemp.isEqualTo(m_PntPrev)) sts = kNoChange; m_PntPrev = pntTemp; } return sts; } AcEdJig::DragStatus CArcTestJig::start() { CString sPrompt; m_Stage = center; sPrompt = _T("\nCenter of arc: "); setDispPrompt(sPrompt); AcEdJig::DragStatus sts = drag(); if(sts != kNormal) return sts; m_Stage = startpnt; sPrompt = _T("\nStart point of arc: "); setDispPrompt(sPrompt); m_pArc->getStartPoint(m_PntPrev); sts = drag(); if(sts != kNormal) return sts; m_Stage = endpnt; sPrompt = _T("\nEnd point of arc: "); setDispPrompt(sPrompt); m_pArc->getEndPoint(m_PntPrev); sts = drag(); if(sts == kNormal) { AcDbObjectId idArc = append(); } return sts; } void CreateArc() { CArcTestJig arcJig; arcJig.start(); }
