unnecessary parts when create a lattice skin in Lattice Commander
1130sirule
1130sirule
Creating a skin with Hollow in the lattice command creates an unnecessary parts. Also, I get an error that breaks the object when I do the generate combine. Please refer to my pictureKakaoTalk_20250227_145041560.pngKakaoTalk_20250227_152556493.png
steffen_anders_adsk
Autodesk Support
Autodesk Support
Skin generation in Netfabb's latticing tools has limitations that make it highly dependent on quality of input mesh. Meshes should be closed and wrapped (form only a single shell), triangles should be as regular as practically possible, skin thickness values must be significantly smaller than shell corners or turns, otherwise heavy self-intersections like in your example are likely.
You will need some or more pre- and post-processing steps to work around these limitations. For example:
  • Apply the Wrap repair action to the mesh and remesh using uniform or adaptive triangle sizes
  • Generate the shell mesh separately (Modify > Generate shell) and use that instead of a shell body in the lattice component
  • Use tools like Boolean intersection and repair to resolve self-intersections and trim off excess mesh
Kind regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online help • System requirements • Knowledge base • Forums • Homepage • YouTube
How to get Netfabb Basic: Video • Help • Download
1130sirule
Hello, thank you very much for your response. If it's not too much trouble, could I kindly ask for a more detailed explanation regarding the part you mentioned:
steffen_anders_adsk
Autodesk Support
Autodesk Support
Using Boolean (https://help.autodesk.com/view/NETF/2025/ENU/?guid=GUID-D3568395-987A-48F2-9EDC-0B888B6A568E😞
  1. Take the cavity shell only and invert it
  2. Use Boolean to subtract from it the lattice mesh
  3. Invert the cavity shell again
  4. Merge cavity shell with the solid original, either using the dedicated command (https://help.autodesk.com/view/NETF/2025/ENU/?guid=GUID-35809251-32C2-4C6A-BCCA-64B8B847391B) or using repair: With the solid original open in repair, drag the cavity shell part in the project tree onto the repair node
Additionally, in repair you have very granular access to the triangle mesh. Here, with tools like Split off self-intersections, manual deletion of excess shells, and Stitch triangles, you can do something similar to Boolean intersecting and unifying. That is a matter of preference.
Best regards,
Steffen
Steffen Anders
