Hi Steffen,
Thanks for your reply.
What are you seeing the peeling on, part, open support, closed support? It is not peeling actually, it is like spark from one corner, and owing to this, to not damage the brush (recoater), we stop process. Upon reviewing my toolpath report data in the SLM Slice Viewer, I noticed that this issue occurred on sample that began printing at the same point during each subsequent layer.
Which machine? Our machine is SLM Solution 280 HL Single
Which build configuration? I print my lattice samples in Z direction. The Scan strategy I applied are either bi-directional with 90 rotation or cross (chess).
EBPA version, if applicable? (R-click in configuration editor > Show configuration info). I did on version V4.32 , the Buildstyle Processor Version : 4.64.0.1211. I also used the default configuration just changing layer thickness (Buildstyle Processor Version : 4.64.0.4)
Netfabb version? 2024 Premium
Thanks for your help, Steffen!
