Spot size
Spot size
Spot size
please have a problem changing spot size.
After rewriting the spot size from 0.150 mm defult to 0.070 mm it will be rewritten back to 0.150 mm.
The renishaw am 400 has a spot size of 0.070mm.
Thank You
Jakub Měsíček
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @Anonymous,
Welcome to the Netfabb forum!
This was addressed with Netfabb 2020. If you update to 2020 or newer, you should no longer see this problem.
Best regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online helpSystem requirementsKnowledge baseForumsHomepageYouTube
How to get Netfabb Basic: VideoHelpDownload
Hello, I have a similar issue:
The spot diameter always resets to 150ym when changing the programming type (e.g. from "programmable" to "diagram")
It doesn't depend on the value.
-Netfabb 2020.3 premium (student version)
-SLM 125HL (down up to 70ym)
I could live with this bug if there was a way to doublecheck the .slm file after export weather the correct spot size was chosen.
