Netfabb Forum
Welcome to Autodesk’s Netfabb Forums. Share your knowledge, ask questions, and explore popular Netfabb topics.
Runtime error on load workspace.
4 REPLIES 4
689 Views, 4 Replies
When I load the "Generic FFF" workspace, I get:
LUA Runtime Error: ["string/workspaces.lua"]:1:External exception E06D7363
With the options of Ignore or Close.
Close will exit Netfabb.
Ignore will continue but not display the Print Settings pane, so no changes can be made and the print cannot be previewed.
This happened after an export/import (of the same profile)
I've uninstalled/reinstalled and this error persists.
Suggestions?
Suggestions?
4 REPLIES 4
alexander.osterKLN9H
Hi Russ,
I am sorry to hear that you are experiencing issues. Can you tell us the version you are using? Actually we have released a new version today (2018.2), so you might want to try if this version already resolves your issue. Just go to the Autodesk Desktop App and update.
Best,
 Alex
Hi Russ,
Best,
 Alex
in reply to: alexander.osterKLN9H
For the record, I am running the Premium Trial 2018.1
I will update to .2 and reply later.  Thanks!
Installed 2018.2.  I'm still having the same problem.
BTW error should have read:  LUA Runtime Error: [string "scripts/workspaces.lua"]:1:External exception E06D7363
That error seems to be a code for file can't be accessed.
Where are scripts stored?  Where are the printer definitions stored?  Is there a reason a repair / uninstall / reinstall would not overwrite those files?
Thanks in advance!
Thanks in advance!
Hi Russ,
it should clean itself, but you could try to manually clean the %appdata%/netfabb directory when netfabb is not running.
Best,
 Alex
Hi Russ,
Best,
 Alex
