PRM File error - too many iterations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi There,
I am trying to create a PRM file on Netfabb Simulation Utility with the following parameter values:
Laser Power: 280 W
Travel Speed: 960 mm/s
Layer Thickness: 0.04 mm
Hatch Spacing: 0.11 mm
Interlayer Rotation angle: 67 deg
Material: Inconel 718
The other process parameters in the PRM file (heat source absorption efficiency, laser beam diameter, and recoater time) aren't as important for my simulation, so I have left them at the default values given in the "New Process Parameters" window on the Simulation Utility.
When I try to create this PRM file, it terminates. The error message reads
"TOO MANY ITERATIONS -- REDUCING DELTA T
REQUIRED DELTA T LESS THAN SPECIFIED MINIMUM
TRY RELAXATION, LINE SEARCH OR REDUCE THE SPECIFIED MINIMUM DELTA T"
I am somewhat new to the software, so I am not sure exactly what this means. Maybe I need to change one of the other parameters (heat source absorption efficiency, laser beam diameter, or recoater time) to a different value that will work with the parameter values I specified above?
If anybody has an explanation for this, it would be much appreciated!
Susan
