Netfabb Forum
Welcome to Autodesk’s Netfabb Forums. Share your knowledge, ask questions, and explore popular Netfabb topics.
Netfabb Simulation Crashing
20 REPLIES 20
Message 1 of 21
2367 Views, 20 Replies
I have been running a few simple simulations lately and the simulation utility seems to be crashing a lot.
I have also noticed that when I hit mesh preview, an error appears saying "the simulation was not successful. Please review the thermal and mechanical output files to troubleshoot the error."
Any help would be great!
Thanks Joe
Thanks Joe
20 REPLIES 20
Message 2 of 21
steffen_anders_adsk
steffen_anders_adsk
Autodesk Support
Autodesk Support
Dear @Anonymous,
Welcome to the Netfabb Forum!
When encountering crashes, please open a support case through https://manage.autodesk.com/cep/ > Support > Contact us, and make sure to append any log files, available either within the Simulation Utility, on the Home tab, or stored in the project folder (alongside the TIVUS file) with the OUT extension.  There is one for the thermal analysis, and another for the mechanical analysis.
At any rate, please make sure you are running the latest release of Netfabb and its utilities, currently at 2018.2.
Kind regards,
Steffen
Steffen Anders
Autodesk Netfabb Team
Netfabb resources: Online HelpNetfabb knowledge baseForumsHomepageYouTube
Dear @Anonymous,
Kind regards,
Steffen
Steffen Anders
Message 3 of 21
in reply to: steffen_anders_adsk
Hi Steffen,
Thanks very much for replying to my message. I reinstalled Netfabb and this did indeed solve the problem.
I do have another query with regards to the simulation utility. When I load the results I am unable to get any stress output data.
Please note that I am currently on the trial version of Netfabb Ultimate and I have selected structural plasticity on the solver settings with all stress results selected as outputs.
I would find the stress results to be very important in my analysis of this software.
Kindest regards Joe
Hi Steffen,
Kindest regards Joe
Message 4 of 21
steffen_anders_adsk
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hi @Anonymous,
You're welcome. I will get back to you as soon as I have the answer to your follow-up questions.
Kind regards,
Steffen
Steffen Anders
Hi @Anonymous,
Kind regards,
Steffen
Steffen Anders
Message 5 of 21
Thanks for sharing it.
Message 6 of 21
Hi Steffen,
Just following up from your previous reply and wondering if you have found if it is possible for me to get stress outputs.
I don't mean to push you, however there is only one week left of the trial.
I would greatly appreciate a response.
Kindest regards Joe
Hi Steffen,
Kindest regards Joe
Message 7 of 21
steffen_anders_adsk
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @Anonymous,
Could you please clarify:
Are you loading the simulation results in Netfabb core?
Please try File -> Import result in Simulation Utility, it should show stresses and all results.
Also, Simulation Utility should automatically load results when a simulation completes.
Kind regards,
Steffen
Steffen Anders
Hello, @Anonymous,
Kind regards,
Steffen
Steffen Anders
Message 8 of 21
Hi Steffen,
Thanks for the swift reply.
When I load the results on Netfabb Simulation, on the tree in the browser there are no values of stress, either von mises or Cauchy.
Please find attached below the  screenshot of the simulation resuts that are obtained (These are with all simulations I have ran).
Also I have noticed in the solver settings under analysis type there is the option of selecting thermal or thermal & mechanical, with no mechanical on its own. Also to note that I am unable to solve locally as I was not sent the local solver with the trial, therefore I have been simulating on the cloud.
Maybe this has something to do with the issue??
I look forward to hearing from you shortly.
Kindest regards Joe.
Hi Steffen,
Message 9 of 21
steffen_anders_adsk
steffen_anders_adsk
Autodesk Support
Autodesk Support
Joe,
do you have a file with a name ending in _mechanical.case in your simulation project folders?
Steffen
Steffen Anders
Joe,
Steffen
Steffen Anders
Message 10 of 21
Hi Steffen,
I have obtained all the relevant thermal and mechanical output files. But I cannot seem to obtain the stress outputs.
Please see the image below of all the files in the results folder.
Also I have tried to attach a zip file of this folder so that you may be able to analyse the problem in detail. However the file size limit is exceeded on this forum. Do you perhaps have an alternative email address I can send it to??
Thanks, I am very grateful for your help.
Hi Steffen,
Message 11 of 21
steffen_anders_adsk
steffen_anders_adsk
Autodesk Support
Autodesk Support
Joe,
Please check the second tab next to Analysis and make sure the stresses are ticked:
Kind regards,
Steffen
Steffen Anders
Joe,
Kind regards,
Steffen
Steffen Anders
Message 12 of 21
Hi Steffen,
In all the simulations I have ran so far I have ticked all the boxes in the results tab. As can be seen from the image below. Solver Settings Screen Capture.PNG
I have noticed that you have turned structural plasticity off in your results tab. Just to note that I have turned it on in all my simulations to yield the most accurate results. I have now ran the simulation again with it turned off to see if it solves the issue. If this has anything to do with it please let me know.
Much appreciated.
Thanks Joe.
Hi Steffen,
Much appreciated.
Thanks Joe.
Message 13 of 21
Hi Steffen,
I have loaded the results with Structural Plasticity OFF and all the STRESS BOXES TICKED and still NO STRESS OUTPUTS. Please see below the image.Results with Structural Plasticity Off - Screen Capture.PNG
I really am baffled at why there are no stress outputs. Also I was wanting to test the heat treatment feature but with no stress results I feel it is not worth while. Any help on resolving this issue would be fantastic.
Hi Steffen,
Message 14 of 21
steffen_anders_adsk
steffen_anders_adsk
Autodesk Support
Autodesk Support
Joe,
please create a support ticket through https://manage.autodesk.com/cep/ and submit the TIVUS file as an attachment, or make it available on a file transfer service and send the download link via PN to me personally.
From your earlier screenshot, make sure to not send box_tivus.stl but the file that has the extension ".tivus".
Kind regards,
Steffen
Steffen Anders
Joe,
Kind regards,
Steffen
Steffen Anders
Message 15 of 21
Hi Steffen,
I am new to this platform and am not sure how to create a support ticket. (There doesn't seem to be any instructions) However here is the tivus file attached.
If this does not work can I email you on a personal email account to speed up the process.
Thanks Joe.
Mod edit: Attachment removed.
Hi Steffen,
Thanks Joe.
Message 16 of 21
steffen_anders_adsk
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hi Joe,
thanks, I have taken the file down and forwarded it for analysis.
Best regards,
Steffen
Steffen Anders
Hi Joe,
Best regards,
Steffen
Steffen Anders
Message 17 of 21
Hi Steffen,
Just chasing up to see if there are any developments with the file?
Kindly note there are only 3 days left of the trial.
I look forward to hearing a response.
Kindest regards Joe
Hi Steffen,
Kindest regards Joe
Message 18 of 21
 Hi all,
Are there any updates on this problem? I am also experiencing the same difficulties. Again I am also using the Netfabb Ultimate trial version. Is there a chance that the trial version is limited and does not provide the stress results?
Best Regards,
Daniel
 Hi all,
Best Regards,
Daniel
Message 19 of 21
steffen_anders_adsk
steffen_anders_adsk
Autodesk Support
Autodesk Support
Dear @Anonymous, dear @Anonymous,
Please make your entire project folder available for download. Make sure to include both TIVUS and AWSPAN files. Then send me the download link via PN.
Kind regards,
Steffen
Steffen Anders
Kind regards,
Steffen
Steffen Anders
Message 20 of 21
steffen_anders_adsk
Autodesk Support
Autodesk Support
This issue should be resolved with the most recent release of the update to Autodesk Netfabb 2018.3. Unfortunately, simulation projects and results created with 2018.2 that were missing certain results will continue to be missing them when viewed in 2018.3.
Kind regards,
Steffen
Steffen Anders
Kind regards,
Steffen
Steffen Anders
