I am using Netfabb 2018. When I want to start a simulation in Netfabb Optimization Utility I get the following error message:
"FEA driver error. Could not transmit data to Nastran: Nascrypt error Code 5"
I already reinstalled Netfabb 2018 but I still have that problem.
Can anybody help? Thanks a lot!
I have almost the same error in Netfabb 2018.2 Optimization Utility.
Any ideas?
the first two and the third one are independent and unrelated.
@jason.murphy Is this still happening, and how often does this occur?
@AlexeyN Would you be willing to share your project files with Autodesk for investigation? Note that the file transfer involved may be rather large.
Kind regards
Steffen
I am facing the same issue. I am willing to share these files. What would be the most convenient way for you to access these files - would a dropbox or google drive link be fine?
And where can I send it to you?
Hello, @vip23,
Yes, either one would be fine if you have them uploaded there already. You can also always create a support case and attach it to it.
Best regards,
Steffen
