I am using Netfabb Premium 2018, trial version. I am trying to add supports to a part but when I go through the menu options under the "Support" tab, all of the parameter names are cut off with a "..." even though there is plenty of horizontal space to display the full name. I can't find anyway to expand the space/column to allow the full name to be displayed. Is there an option somewhere that will enable me to read the whole names of the parameters? Please see the image below. Thanks!
I found the answer: there was a faint grey vertical bar at the top of the list that can be moved left to right to enlarge the horizontal space for text.
Hi Steve,
thank you for the feedback! We will try to improve the user experience for this.
Best,
Alex
