How to set label font in Lua scripts
blinue
Observer Observer
blinue
Observer
Observer
Hello everyone!
We are using Lua scripts to automate mesh labeling. I have read through the documentation of Stamper and found that it doesn't provide an API to customize the typeface. According to the documentation: "The stamper uses the typeface, size, style, and variant set in the Settings." I tried changing the default label font in Netfabb's settings, but it didn't work. Could anyone please advise on the correct way to set the label font?
Thank you!
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @blinue,
Welcome to the Netfabb forum!
I must apologise, the documentation is wrong. The typeface selection, including its weight, variant, style, size, and other parameters currently have no effect on the Lua stamper; they are set internally to defaults when the object is created and there are no properties or methods exposed to affect them.
I will correct the documentation.
Kind regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online helpSystem requirementsKnowledge baseForumsHomepageYouTube
How to get Netfabb Basic: VideoHelpDownload
blinue
Observer
Observer
Thank you for your quick response! So, it's not possible to change the label font in Lua? Are there any alternative solutions?
steffen_anders_adsk
Autodesk Support
Autodesk Support
With the release of Netfabb 2025.1 today, this has been fixed and even expanded with greater customisability.
The documentation page https://help.autodesk.com/view/NETF/2025/ENU/?guid=NETF-LUA-STAMPER has been updated accordingly.
Steffen Anders
