Error repairing a model through Prusa Slicer
giladk
giladk
Although this issues happened when using Prusa Slicer, it is related to the Netfabb fixing operation executed under Prusa Slicer and the object I'm trying to repair was generated using Fusion 360.
Of course is is possible to use STL/3MF files but using STEP files is much 'smarter' and results and smoother and more accurate products.
Plz see the following images explaining the issue.
I've also attached the files. If this is not the riht forum for this kind of issues plz feel free pointing me in the right direction.
Thanks.
steffen_anders_adsk
Autodesk Support
Autodesk Support
The "Netfabb fixing operation executed under Prusa Slicer" is not a service operated or supported by Autodesk.
Kind regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online help • System requirements • Knowledge base • Forums • Homepage • YouTube
How to get Netfabb Basic: Video • Help • Download
Sualp.Ozel
did you try using the MANUFACTURE workspace in Fusion 360 to slice your models for your Prusa printers directly in Fusion 360 an generating your G-code?
That way you do not have to deal with export / import cad / mesh files
The entire workflow is also automated with a python script using Fusion 360 APIs
you can simply copy / use it to automate the entire workflow.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-{482C239A-22E9-4943-A63F-70CAA8C6CC1B}
Sualp Ozel, PE
Principal Product Manager
giladk
I didn't try but I'll give it a go.
